Compact Rear Wiper Failure...help Please? - BMW Forum - BimmerWerkz.com
Old 04-15-2005, 01:26 AM   #1 (permalink)
Boxbrownie's Avatar
Boxbrownie is an unknown quantity at this point
Send a message via AIM to Boxbrownie Send a message via MSN to Boxbrownie
Hi,
My rear wiper has ceased to operate, the funny thing is if I hold the stalk forward or give it several pushes forward occasionally it will work. I assume it can't be a fuse or the thing would not work at all, I know how to operate it properly and I have tried the key off then try again method!
I can only assume its some kind of electrickery problem in a black box/chip somewhere, has anybody had a similar problem....and found an answer of course!
Best regards David
Boxbrownie is offline   Reply With Quote
Old 04-15-2005, 01:34 AM   #2 (permalink)
Power Shifting
Cruzin 323is's Avatar
it might be a relay, u should check the wireing..
-SOLD..
R.I.P Fast 6
Old 04-15-2005, 01:44 AM   #3 (permalink)
Boxbrownie's Avatar
[snapback]332711[/snapback]
Yes, sticky relay....it only happened yesterday, I will be checking out the fuses and relays tomorrow (sat) when I have more time. hopefully it will be something as simple as that....hopefully!
Best regards David
Old 04-15-2005, 06:47 AM   #4 (permalink)
NeverLeaned is an unknown quantity at this point
Send a message via AIM to NeverLeaned
Its the motor. The teeth in the cogs (Probably only the first couple) are worn down. Thats why when you give it a push it completely the cycle (your pushing it past the bad teeth)
Typically those teeth are made of plastic..........
Typically they wear down premature from using your wipers to remove heavy snow from your window......
1996- BMW 328IS
<img src='http://img.photobucket.com/albums/v242/gws226/TEX/neverleanedsig.jpg' border='0' alt='user posted image' />
Performance: Zimmerman Cross Drilled Rotors-- PBR Deluxes-- Cosmos CAI---- Turner Pulley Kit--- Fan Delete mod---
Beauty: 18 polished M-Parallel replicas, Inpro Euros w/ Enchanced Angel eye kit, 20% tint
Clear corners/sidemarkers ---- Eurospec (Depos)
To do list:
Suspension--- researching
UUC System U TDM- 3/05
M50 manifold converstion 3/05
NeverLeaned is offline   Reply With Quote
Old 04-15-2005, 08:16 AM   #5 (permalink)
Boxbrownie's Avatar
[snapback]332752[/snapback]
No no, I did not mean physically pushing the blade, I was talking about the control stalk on the steering column, if I push that several times forward to the wipe position it occasionally works, sorry for the confusion.
I did try jiggling the blade, but that made no difference.
I will check fuses and relays this weekend.
Best regards David
Old 04-15-2005, 01:39 PM   #6 (permalink)
oopss... disregard my post LOL!
1996- BMW 328IS
To do list:
Rear Shock Mount Failure redd90 3-Series (E36) 7 07-05-2005 01:59 PM
Rear brake light failure bitcore 3-Series (E36) 7 08-21-2004 02:02 PM
Rear power window failure Minardi 5-Series (E12,E28, E34, E39, E60) 2 08-14-2004 01:23 AM
List of common e46 part numbers L337E46 3-Series (E46, E90) 0 06-07-2004 09:19 AM
