Cold feet... - BMW Forum - BimmerWerkz.com
Old 04-20-2004, 10:59 PM   #1 (permalink)
Help is an unknown quantity at this point
Sup all.. I'm new to the forums.
I'm considering purchasing a 98 328 but found something minor, but troubling; is that under power the steering wheel does a slight shimmy. (Not real bad... ) I asked the sales person whats up and he said it's because all BMWs have the issue when 18in wheels are installed. Knowing something about physics this seems lame that BMW engineers haven't resolved or accounted for this problem. There is no exaggeration during braking and it's not much of a problem above or below 40Mhp. I think the wheels are out of balance yet he states that they were just balanced a week ago. Whats your thoughts?
Help is offline   Reply With Quote
Old 04-20-2004, 11:23 PM   #2 (permalink)
Aggieland81's Avatar
Aggieland81 is an unknown quantity at this point
Send a message via AIM to Aggieland81
i have this same problem, its only around 40 mph but i have a 93 though, if u find out what it is let me know
<img src='http://www.bmw-forums.com/forum/uploads/post-4-1083708618.jpg' border='0' alt='user posted image' />
Aggieland81 is offline   Reply With Quote
Old 04-20-2004, 11:24 PM   #3 (permalink)
welcome to bmw-forums
the tires could be unbalanced(still), out of round, or the center bore of the wheels are not the correct size for the 328s hub (<-very common and is the most likely cause). if bmw did not make the wheels, or if they werent made exactly to bmw specs, its stupid to blame the car for a wheel shimmy problem
Old 04-20-2004, 11:45 PM   #4 (permalink)
Defector
El Presidente's Avatar
yeah, I would tell dealership to put a different set of wheels on it and let you test drive it then. If it is still there, you know its the wheels. If not, its something like alignment. If its a good dealer they should accomodate you and change the wheels out though.
Old 04-21-2004, 12:04 AM   #5 (permalink)
Awesome!!! Thanks for the insight. Yeah probably just what I needed to hear. I'll make them do that (change out the wheels.) If all else is well and I get it I'll post a picture.
Thanks again.
-noob
Old 04-21-2004, 07:53 AM   #6 (permalink)
Andrewsd1985's Avatar
Andrewsd1985 is an unknown quantity at this point
Send a message via AIM to Andrewsd1985
Good luck. MAybe even check the lower control arm bushings, usually the shimmy happens at higher speeds but 40 isn't unreasonable, and this is a common problem in e36s (non M)
PRESIDENT OF THE OVER 10 YEARS OLD AND UNDER 100K MILES CLUB
1993 325i 5spd
Benfer Performance Intake
M-tech Pedals and Shiftknob
Bavarian Auto Floor Mats
Wheelskin Steering Wheel Cover
Panasonic Head Unit
Euro Projector Lights w/ black Housing
Black Housing Clear Corners
Dinan Chip
MORE TO COME!!
<img src='http://plaza.ufl.edu/dunna/Pictures/banner.jpg' border='0' alt='user posted image' />
Andrewsd1985 is offline   Reply With Quote
Old 04-21-2004, 11:16 AM   #7 (permalink)
Keep it Copacetic
///M Power's Avatar
Car: 1995 BMW M3
actually the porblem may lie in the suspenion and steering links. It may be the front ball bearings, control arms, tie rods, and other steering links.
Old 04-21-2004, 11:41 AM   #8 (permalink)
Car: 97 328is, 93 318is
thinair is on a distinguished road
Send a message via ICQ to thinair Send a message via MSN to thinair
I had this on my car, first it was the lower control bushings, I replaced mine with urethane ones. Then it was my inner control arm ball joints, so I just replaced the control arms. It fixed it.
Start with the cheaper solutions first, get the wheels rebalanced, then see if there is a lot of deflection in the lower control arm bushing. Lift the front of the car, see if there is any noticable play in the ball joints, tie rods, wheel bearing, etc, etc.
It's not an uncommon problem, but not impossible to fix either.
Nelson Papel
1997 Madeira Violet 328is - Carbonio Intake, Racing Dynamics exhaust, fan delete, ASC delete, M50 intake manifold, M3 Cams, Eurospeed/AA software, 3.38LSD, M3 f&r brakes + MC, Bilstein PSS, Eibach swaybars, BBS RK 17x8&quot; wheels, Toyo T1R (235/40R17) tires, Racing Dynamics K55 kit, full euro lighting, 4300k HID lows, etc..........
<a href='http://www3.sympatico.ca/thinairbikes/bmw.htm' target='_blank'>Click here for more info on my car</a>
thinair is offline   Reply With Quote
Old 04-21-2004, 07:02 PM   #9 (permalink)
socalguy is an unknown quantity at this point
hey i have a 96 328is and mine has the same problem, however its
becuase i bent the rims... its not real noticable especially after you get
the tires balanced,,, but rims are NOT cheap!!
socalguy is offline   Reply With Quote
Cold Air Intake? KevinTS 3-Series (E36) 40 03-28-2005 02:17 PM
Cold Air Intakes? Rooz 3-Series (E36) 58 02-04-2005 03:58 PM
Cold Air Intake - Is it worth it? Jog5000 3-Series (E21, E30) 17 08-10-2004 02:36 PM
faster leak when cold. dubumb 5-Series (E12,E28, E34, E39, E60) 12 02-02-2004 09:42 PM
1989 325ix cold start problems All wheels rolling 3-Series (E21, E30) 0 10-19-2003 06:29 PM
