yes, I have the cosmosracing one and it matches the rest of the underhood parts nicely. It has a good clean growl starting around 1/4 throttle. You have to relocate the horns tho. This will need to be done with any CAI, however.
Either one of them with the heat shield would be great. Just be careful not to run through deep water or heavy rain where water might get injested into the motor. There is a water bypass adapter to install to help prevent that.
__________________ Hookers need love too!
One thing to remember, if you do not enclose that filter, or get it out of the engine compartment you are still inhaling hot air and hot air does not make horsepower.
Originally posted by 4DR Daemon@Aug 25 2005, 05:51 AM be carefull with a CIA that is why i had to replace my engine earlier this summer. make sure to get an AEM bypass valve.
means that the "cia" aka cold air intake setups , normally dont come with a water bypass valve and since most cia s are closer to the ground
or lower than the stock level if you run into a puddle of water then water goes into the engine via the cia ,hidrolocking your engine and the
water bypass valve prevents that by sucking air trough the minifilter instead of sucking water as water is heavy .
I think it goes inbetween the engine end of the cold air intake and the throttle body.
