HELP
I just got A 92 325I last night.and the car is not running now,i checked the fuel pump ,and the pump is good.fuel pump relay,main relay are good.crank sensor are good. and there is no power to fuel pump.and there is no spark too.i pulled the code from CEL ,code 1261
Fuel Pump Relay Control code indicates break or short circuit associated with fuel pump relay. Test for proper signal on number 3 pin on DME. It can also mean that output stage of DME is faulty (Motronic version 1.3 only)
1.Test for proper signal on number 3 pin on DME ( how is this done?)
2. output stage of DME is faulty (what does it mean?)
3.does the Fuel Pump Relay Control kill to ignition system(spark)
help please. thanks
help please. thanks
