clutch woes - BMW Forum - BimmerWerkz.com
Old 03-08-2006, 06:29 PM   #1 (permalink)
ex owner/admin
Furious's Avatar
clutch woes
ok so as people know , i did the s50 swap into my car so i have a bit more power than your usual 325, my clutch was sufficient for the time being, but now i wanna put in the m3 clutch that i have laying around, the problem i encountered was that the m3 clutch is from a 1998 M3,ZF transmission..and my 325 tranny is getrag. now i tried to put it in and it didnt fit, the throwout bearing was pushing the clutch teeth in much too far, make a horrible grinding noise....
what i have-pressure plate, flywheel, and clutch disk
ok for the questions.
-what is involved with the clutch setup? i figured it was slave, throwout, pressure plate, clutch disk, flywheel.. am i missing any components?
-second question will this clutch fit in my car if i get the missing components? or am i wasting my time?
i understand i should upgrade to a performance clutch and flywheel, but at the time i dont have the $$$, and i already have the M3 clutch since last year.
Old 03-09-2006, 07:19 AM   #2 (permalink)
Dudesky_E36's Avatar
Car: Anthracite e39 530iA
Dudesky_E36 is an unknown quantity at this point
Send a message via AIM to Dudesky_E36
I'm not too schooled in this, but from what I was told, the flywheels, clutch discs and pressure plates are not interchangeable between ZF's and Getrag's. I have a Getrag 250 that needs to be replaced, and I'm told that I would need to change those parts as well to upgrade to a ZF.
Dudesky_E36 is offline   Reply With Quote
Old 03-09-2006, 11:38 AM   #3 (permalink)
93 325i's Avatar
You can absolutely put an M3 clutch on a getrag tranny. I dont have any specific info for you, but was quoted $800 for complete M3 clutch/flywheel and labor. With that said it is definitely possible..
Complete mod list and pics:
My 1993 325i
Old 03-09-2006, 12:33 PM   #4 (permalink)
ex owner/admin
Furious's Avatar
hmmm, does anyone have teh etk? i know that the ZF tranny clutch is slightly thicker, but is the zf throwout smaller than the getrag one, and or does the slave cylinder have any connection to this?
E34 Clutch Switch -- HELP ! ! ! m3driver97 5-Series (E12,E28, E34, E39, E60) 5 10-28-2005 05:22 PM
Problems with M3 clutch after install Autotechnica 3-Series (E36) 20 07-03-2004 07:01 PM
E36 M3 UUC Flywheel Wrong Clutch Becherert 3-Series (E36) 1 03-09-2004 01:39 PM
Fan clutch woes..... =( TeamPSI 3-Series (E36) 4 03-04-2004 02:57 PM
home-made clutch stop woobiee Picture Showroom 7 02-11-2004 01:14 AM
