Clutch Problems Urgent Assistance - BMW Forum - BimmerWerkz.com
Old 07-23-2005, 04:06 AM   #1 (permalink)
mmclaren is an unknown quantity at this point
ok everything was going great. Put my car in the driveway, had a coffee watched some tv..
went outside to move it into the garage but the clutch just goes in, i push in the clutch pedal and nothing happens.. It is extremely easy to push in..
what could have happened...
It was perfect the last time i drove it..
bmw 318i m43 1995
mmclaren is offline   Reply With Quote
Old 07-23-2005, 04:20 AM   #2 (permalink)
I think its clutch fluid all over the ground...
Or some sort of oil, seems like a thin clearish oil
Old 07-23-2005, 04:54 AM   #3 (permalink)
Dudesky_E36's Avatar
Car: Anthracite e39 530iA
Dudesky_E36 is an unknown quantity at this point
Send a message via AIM to Dudesky_E36
Brake fluid. It's a hydraulic clutch (no cable), and shares the same fluid as the brakes. Beyond that, I'm not sure where you should start . . maybe some more experienced folks here can help . .
Dudesky_E36 is offline   Reply With Quote
Old 07-23-2005, 05:10 AM   #4 (permalink)
Checked the hydraulic fluid it was fine..
Its been leaking alot.. and seems to be another pile near the back, where the rear dif is, but i cant be sure that its not the same leak
Old 07-23-2005, 10:00 AM   #5 (permalink)
Gator is an unknown quantity at this point
If you have fluid all over the ground and no clutch, it is about 99% certain that you have a brake fuild leak. The clutch and the brakes share the same resevoir and the clutch doesn't work either because it lacks fluid, or because hydraulic pressure is being lost due to the leak. The car needs to be put on a lift and inspected. It may help to have someone push the clutch in while someone else looks for the leak.
In any case the car should NOT be driven any farther than absolutely necessary because with this condition you could lose all brake function at any moment.
Gator is offline   Reply With Quote
Old 07-23-2005, 11:34 AM   #6 (permalink)
its not drivable atm, i have 0 pressure in the clutch, brakes though seemed to still function ok, just quick testing..
Also seems like there may be the same leak at the back of the car near the rear dif... not full sure though
Old 07-24-2005, 12:52 AM   #7 (permalink)
catalyst. is an unknown quantity at this point
Send a message via AIM to catalyst.
Find out where the leak is, if its leaking brake fluid, it is def. a ruptured brake line because the clutch line doesnt go to the rear of the car.
catalyst. is offline   Reply With Quote
Old 07-24-2005, 05:18 AM   #8 (permalink)
ahh ok, just seemed to be comming from near the rear differential and the gearbox, so this could still be a ruptured brake line.. and wouldnt that mean its been rupered twice.. bit strange
Problems With Spec Clutch And Their Service... Dustin540-6 5-Series (E12,E28, E34, E39, E60) 4 08-09-2007 12:20 AM
E28 Clutch Problems (help!) limbick 5-Series (E12,E28, E34, E39, E60) 2 04-20-2005 03:25 PM
Problems with M3 clutch after install Autotechnica 3-Series (E36) 20 07-03-2004 07:01 PM
E36 M3 UUC Flywheel Wrong Clutch Becherert 3-Series (E36) 1 03-09-2004 01:39 PM
