Clutch problems - BMW Forum - BimmerWerkz.com
Old 03-31-2006, 09:06 AM   #1 (permalink)
E36 325I's Avatar
E36 325I is an unknown quantity at this point
Send a message via AIM to E36 325I
Clutch problems
on my morning drive to school i noticed that my clutch pedal was acting weird...There was no pressure on the pedal untill i pushed it down about 6 inches. Could this be somthing to do with the transmission fluid and where do i check the fluid...I was also wondering if it could have somethin to do with the slave cylinder. At school right now and am hoping that i can get the car back home this afternoon. by the way its a 92 325i 5 speed
I also noticed the pedal stuck down about 5 inches off of the floor and would not rebound back to normal position
New slave cylinder or waht?
E36 325I is offline   Reply With Quote
Old 03-31-2006, 04:18 PM   #2 (permalink)
e36surge's Avatar
sounds like a leak and it sounds like you have air in the system.
- Mario Andretti
1979 320is RiP
1994 318is Sold
1995 325is Sold
1995 530i Sold
2004 M3
Old 03-31-2006, 10:44 PM   #3 (permalink)
E36 325I's Avatar
yeah i hope its just a leak because i really dont want to have to tear apart my whole dash to replace the slave cylinder... i also found out from my mechanic that the brake master cylinder also runs the clutch so im going to fill it with fluid and then try bleeding it
thanks for the reply surge
keep you posted when i figure the problem out tomorrow
Old 04-02-2006, 09:47 AM   #4 (permalink)
Tochenzo's Avatar
Tochenzo is an unknown quantity at this point
Send a message via AIM to Tochenzo
i don't really get pressure until a good way down either...but it's been like that since i first got m ycar so i assumed it was normal used:
Tony
National Capital Chapter BMW CCA #367673
1998 Hellrot 328i
Tochenzo is offline   Reply With Quote
Old 04-02-2006, 09:35 PM   #5 (permalink)
kyle_baker's Avatar
kyle_baker is an unknown quantity at this point
Send a message via AIM to kyle_baker Send a message via MSN to kyle_baker Send a message via Yahoo to kyle_baker Send a message via Skype™ to kyle_baker
i'm pretty sure you're gonna have to replace the slave cylinder.
my clutch did the same thing about 6 months ago. I kept adding brake fluid for like a week and finally took it to the mechanic. ended up being the slave cylinder leaking. wasn't too expensive tho. can't remember the exact amount.
cheers!
kyle_baker is offline   Reply With Quote
Old 04-04-2006, 05:15 PM   #6 (permalink)
E36 325I's Avatar
My dad and I added fluid this weekend. Then bleed the system and it seems to be ok now. But still looses pressure occasionally. I think i will replace the slave cylinder but has anyone done it themself before...dont really have the extra money to bring it somewhere because i spent it all on my coilovers...If anyone knows of a DIY writeup for the slave cylinder let me know
Thanks for the info
Problems With Spec Clutch And Their Service... Dustin540-6 5-Series (E12,E28, E34, E39, E60) 4 08-09-2007 12:20 AM
Clutch problems? MalibuSean M-Series (M1, M3, M5, M6) 0 09-08-2005 12:45 AM
E28 Clutch Problems (help!) limbick 5-Series (E12,E28, E34, E39, E60) 2 04-20-2005 03:25 PM
Problems with M3 clutch after install Autotechnica 3-Series (E36) 20 07-03-2004 07:01 PM
home-made clutch stop woobiee Picture Showroom 7 02-11-2004 01:14 AM
