| Clutch pedal engaging low to floorboard I know there were several posts about this and it has been a problem for me as well... anyway, I took it in for a clutch diagnosis and it has been discovered that the pedal assembly is worn out. Evidently the holes thru which the pivot pin goes thru is WAY wallowed out. This is a possible explanation for the problem. As soon as it is replaced i will know more. |
