Clutch pedal engaging low to floorboard - BMW Forum - BimmerWerkz.com
Old 10-17-2011, 11:13 PM   #1 (permalink)
hownnq is on a distinguished road
I know there were several posts about this and it has been a problem for me as well... anyway, I took it in for a clutch diagnosis and it has been discovered that the pedal assembly is worn out. Evidently the holes thru which the pivot pin goes thru is WAY wallowed out. This is a possible explanation for the problem. As soon as it is replaced i will know more.
hownnq is offline   Reply With Quote
Old 10-30-2011, 11:13 PM   #2 (permalink)
Car: 1994 E36 318I
Frozen 318i is on a distinguished road
Wild!
I worked for a shop, I hope this is your problem and not that is what they tell you for you to come back and give them more money for a clutch. Not to be negative. just never heard of a worn paddle assembly, is it loose in any direction?
Frozen 318i is offline   Reply With Quote
Old 11-01-2011, 02:52 PM   #3 (permalink)
theluis's Avatar
Car: 1995 BMW 325i 5 Speed
theluis is on a distinguished road
I had the same problem and eventually it got worse but the problem with mine was that my slave cylinder was leaking (very little) but it would loose pressure at times and just go straight to the floor. What you might try is bleeding your system, but not the conventional way it says in the service manual. What you do is get a big syringe and fill it with brake fluid then remove the small feed hose that goes to the brake master cylinder stick the sringe in the hose and push down on the syringe to mke pressure this will pull the bubbles out of the system when you release the pressure on the syringe. If the pedal is higher up after you do this the you most likely have a small pressure lei in the system somewhere.
theluis is offline   Reply With Quote
Spark Plug Replacement? Bosch Platinum Plus or Bosch Super? Delmarco 3-Series (E36) 9 05-03-2008 01:23 PM
Real Euro Headlights LivinFast67 3-Series (E36) 6 07-31-2005 11:44 AM
What Brand To Go With Euro Headlights? keikun M-Series (M1, M3, M5, M6) 9 06-07-2005 03:47 PM
zkw euro spec headlights w. angel eyes B_w. 3-Series (E36) 3 07-14-2004 11:23 PM
Upgraded to Euro headlights mostwired 3-Series (E36) 20 12-19-2003 09:21 AM
