i burned my clutch a little bit today while testing the acceleration of my car.... the smell was pretty bad... gears seem to go in and out fine... my question is if i blew out my input/output transmission bearings would my engine light come on? or any light?
Your check engine light wouldn't come on if you had a transmission problem. The fact that your clutch slipped so bad as to cause a smell is a problem within itself.
shouldn't be a big deal, just don't make a habit of slipping your clutch. if you need a clutch replacement then do it. if you wait too long, with constant slipping you will heat your flywheel too much causing it to crack. getting a flywheel machined isn't expensive, buying a new one is
Don't make a habit out of it man; clutch replacements are neither cheap nor easy. Unless it's slipping under normal driving now, take it easy on it for a few days and you'll be fine.
If this is the only time you have slipped you clutch in this way, you will be fine. Just don't make a habit of it or you will end up on the side of the road with a burnt up clutch.
__________________ FCP Groton
877-634-0063 | info@fcpgroton.com FCP Euro - European Car Parts Specialists FCP Import - Import Replacement Car Parts
