Clutch hits floor, No resistance! - BMW Forum - BimmerWerkz.com
post #1 of 5 (permalink) Old 03-27-2009, 07:53 AM Thread Starter
pmsskg is on a distinguished road
Hello everyone I own a 1993 325IS 2door coupe 5speed... I was driving to work yesterday morning and everything was fine, park my car 1st, ebrake of course... Go outside at the end of the day to start my car and I press on my clutch and it just hits the floor... I was like wtf!!! so i pulled it back up with my hand and it did it again.... freaked out tried to crank my car and it didn't do anything.....
No pressure in the clutch, it seems like once the clutch gets past the lever action of the clutch it feels like a magnet is pulling it to the floor... I have done alot of research online, and I am pretty sure it is the Clutch master cylinder or the slave cylinder... Also something that might help I think I heard about brake and clutch going to the same place on these M50 engine E36 chassis cars....
I added day before yesterday Valvoline Dot 3 & 4 Brake liquid... Car says only use Dot 4... That could be a problem.. I guess I am going to have my car dollied down the mountain to a shop and go buy a slave cylinder andf a clutch master cylinder and try it out....
I am just freaking out, I love this car.... Coolest car I have ever had, I am 22 and own my own beemer..... I just wish I had some guide lines.
So yes PMSSKG here, new member and I think I am really working my self up over nothing.... But I dunno, plz help you guys..... I have to go to work, I will check my thread when I get home....
Thank you for your time and consideration.
pmsskg is offline
post #2 of 5 (permalink) Old 03-27-2009, 09:25 AM Thread Starter
also I can not seem to find a clutch fluid reservoir to check the clutch fluid....
pmsskg is offline
post #3 of 5 (permalink) Old 03-27-2009, 07:59 PM
jmo69's Avatar
jmo69 is on a distinguished road
The clutch master shares the same resevoir as the brakes. and yes it is most likely the slave. It's pretty easy to change, just clamp the hose to prevent the fluid from leaking any more than neccesary. Once the line is reattached, unclamp and open the bleeder and allow fluid to run out. Make sure the brake res. is full, then with the bleeder still open push the shaft in and close the bleeder, this will get most of the air out. When you reinstall it into the bell housing you should feel the resistance of the shaft being pushed in, this will tell you that it's contacting the clutch fork. This is critical, other wise when you push the clutch pedal down the shaft can pop out and fall into the bell housing, not good! After that just bleed it till the pedal is good and firm. Pelican Technical Article: BMW Clutch Slave Cylinder Replacement
Cosmos schwartz metalic Sparco strut brace factory X-brace 55w 6000k HID w/LED angel eyes smoked Lamin-X blacked out sidemarkers,tails and brakelights. DDM smoked corners and pedals. 35% tint all around, Prosport water temp and oil pressure gauges, Home Depot lip, M3 rear diffuser ASC-T delete.
jmo69 is offline
post #4 of 5 (permalink) Old 03-28-2009, 07:51 AM Thread Starter
jmo69 thank you for your reply, seems pretty easy.. lets just hope its the slave cylinder.... I did notice now that I retrace my steps that as I was pulling into work the clutch did feel a little funny, still tight in pressure but the pressure decided to start a little late than normal... but thanks jmo69!
pmsskg is offline
post #5 of 5 (permalink) Old 04-09-2009, 03:35 AM
inajar91 is on a distinguished road
mann the same exact thing happened to my car turns out it was a faulty slave cylinder however they did have to replace both master and slave cylinder. so for a day i was forced to put in brake fluid and pump the clutch a billion times till it got the resistance back (ghetto i know) hey but it still held till i would turn off my car for the night and go to sleep until i would have to do it again in the morning to take it to a shop lol
inajar91 is offline
Clutch Has No Resistance...need Help!! SDSUe36 3-Series (E36) 16 04-06-2011 02:48 PM
Help: Aux fan magna resistor, What is the resistance? Rfitz25 3-Series (E21, E30) 7 08-15-2007 01:46 PM
'93 740 fuel injector resistance testing beameup 1,6,7,8 - Series and Mini Cooper 0 02-01-2007 06:10 PM
ABS Rear Inlet Valve Resistance Readings retirednow Bimmer Talk/Motorsports Talk 0 06-09-2004 02:40 PM
'92 325is Clutch-sticks to the floor Brendan430 3-Series (E36) 2 01-12-2004 11:59 PM
