Clutch - BMW Forum - BimmerWerkz.com
Old 07-22-2004, 04:17 PM   #1 (permalink)
Kevin325i's Avatar
So yeah, I was attempting a 0-60 run today, best I came down with was a 8.20. Quite a bit off from where I should be getting. So at the launch from 4k, the car boggs. Ok step it up to 5k. Car slips the clutch like a mofo.
Either the car boggs, or slips the clutch. Then when I shift into second the car just goes vrooooooom at 6k while the clutch just slips lol. My worse time was like a 9.52 or something with a launch from 5k and like 2 seconds of slippage at 6k in second.
Yeah I'm just kinda venting cause my clutch blows. A 5k launch (I slip the clutch instead of dumping it, better for the drivetrain because the clutch is supposed to wear, rather have that go then my differential or something) should light the tires, and it shouldn't slip at 6k in second for 2 seconds lol. This was after I let the clutch cool for about 5mins. I just drove for 5 or 6 mins without shifting.
So basically, what are my options for a clutch with some better lock up. I'm thinking just go all M3, clutch, flywheel, pressure plate. Or can I get the e34 M5 clutch into the mix so it's not dual mass and so I can use it with my normal clutch slave cylinder and not upgrade to the M3.
Kevin
Kevin (President TBEA)
Old 07-22-2004, 09:33 PM   #2 (permalink)
ex owner/admin
Furious's Avatar
you need a clutch soon
it sounds like the teeth on the pressure plate are worn pretty good. no clamping power when your hard on the gas
Old 07-22-2004, 09:53 PM   #3 (permalink)
Kevin325i's Avatar
I know I'm looking right now how much this crap is going to run me.
Old 07-22-2004, 09:54 PM   #4 (permalink)
Kevin325i's Avatar
I know I'm looking right now how much this is going to run me, so far it isn't looking good.
Anyone know if the e34 M5 clutch and M3 flywheel and pressure plate will work together?
Old 07-23-2004, 05:07 AM   #5 (permalink)
brien4787's Avatar
brien4787 is an unknown quantity at this point
Send a message via AIM to brien4787
doesnt it cost like 6-800 dollars or so just to replace a clutch???
brien4787 is offline   Reply With Quote
Old 07-23-2004, 09:27 AM   #6 (permalink)
ex owner/admin
Furious's Avatar
yeah its about that in USD
Old 07-23-2004, 09:44 AM   #7 (permalink)
kestrel325is's Avatar
Car: 1995 325is 5-speed
kestrel325is is an unknown quantity at this point
Is it possible for you to do it yourself? I know that you can get the clutch kit for about $100. I'm getting ready to do mine in a couple of weekends. Clutches are fairly straightforward to replace.
kestrel325is is offline   Reply With Quote
Old 07-23-2004, 07:30 PM   #8 (permalink)
Kevin325i's Avatar
Yeah I'm doing it myself. 200 bucks for a clutch kit, but I'm looking to go M3 with this so I need a flywheel.
Anyone know how much all the pieces weigh for the e36 M3 e34 M5 and the 325?
Old 07-24-2004, 12:22 AM   #9 (permalink)
Kevin325i's Avatar
Well for 500 bucks I'm going for the clutch masters setup. Basically the sachs kit with a higher clamping force and twice as much B)
I wanted to go M3, but that's going to be like 800 bucks unless I find a used M3 flywheel.
Old 08-06-2004, 12:54 AM   #10 (permalink)
Crispy222's Avatar
Crispy222 is an unknown quantity at this point
Send a message via AIM to Crispy222 Send a message via Yahoo to Crispy222
Check out http://www.bimmerworld.com/html/bimmerworl...t-flywheels.htm for some weights on flywheels.
I'm in need of a clutch myself but I think not as bad as you. So tell me what not to do so I don't waste my money in 6 months.
Chris
VIP Helen '95 325IS 5sp T-boned
Viva la Victoria '96 328IS 5sp w/ some Dinan
<a href='http://www.cardomain.com/memberpage/752493' target='_blank'>Car Domain Site</a>
<img src='http://memimage.cardomain.net/member_images/8/web/752000-752999/752493_2_full.jpg' border='0' alt='user posted image' />
Crusin w/ an e46 M3 at 145 on the dial and revs to spare. Saftey with a V1
Crispy222 is offline   Reply With Quote
Old 08-06-2004, 01:06 AM   #11 (permalink)
Kevin325i's Avatar
perfect that means the stock 325 flywheel is the same as the M3. So I'm not making the rotational mass any larger. Well not the flwheel atleast. I'm sure the clutch will have some extra weight
Old 08-06-2004, 05:28 AM   #12 (permalink)
Tygrys is an unknown quantity at this point
You need a nw cluch man
i had 3 clutches fitted last year cos 2 were some japanise made ones(bit cheaper than original one)so get a good staff if you dont wanna do it again in 3 months time
Tygrys is offline   Reply With Quote
Old 08-06-2004, 08:44 AM   #13 (permalink)
nycbmw325is is an unknown quantity at this point
hey furious .. can you explain to me what the clutch teeth are?
nycbmw325is is offline   Reply With Quote
Old 08-06-2004, 12:09 PM   #14 (permalink)
Kevin325i's Avatar
He means the fingers on the pressure plate that clamp everything together. Check out How Stuff Works and search for clutch.
E34 Clutch Switch -- HELP ! ! ! m3driver97 5-Series (E12,E28, E34, E39, E60) 5 10-28-2005 05:22 PM
Is It My Clutch? kyle_baker 3-Series (E36) 16 10-18-2004 04:20 PM
Problems with M3 clutch after install Autotechnica 3-Series (E36) 20 07-03-2004 07:01 PM
E36 M3 UUC Flywheel Wrong Clutch Becherert 3-Series (E36) 1 03-09-2004 01:39 PM
home-made clutch stop woobiee Picture Showroom 7 02-11-2004 01:14 AM
