Cluster ? - BMW Forum - BimmerWerkz.com
Old 09-28-2004, 06:47 PM   #1 (permalink)
Brian325i is an unknown quantity at this point
I'm going to buy a used m3 cluster because the guy I bought my bimmer from had installed these cheap ebay indiglo gauges and plus it's scratched up. My question is, If I get a used cluster...does the odometer need to be reprogrammed to my car's actual miles or is the odometer computerized...meaning, will show the car's actual odometer reading for any car once plugged in?
Brian325i is offline   Reply With Quote
Old 09-29-2004, 08:39 AM   #2 (permalink)
Caps is an unknown quantity at this point
Yep the cluster contains the mileage info so it will have to be reprogrammed. Note that the cluster also contains other info if I remember correctly so best bet would be to take it to a BMW agent and have it reprogrammed.
Caps is offline   Reply With Quote
Old 09-29-2004, 10:02 AM   #3 (permalink)
/Banned
okczy21 is an unknown quantity at this point
you could just take off the indiglo gauges, they are just overlays on the stock ones
okczy21 is offline   Reply With Quote
Old 09-29-2004, 04:22 PM   #4 (permalink)
Yeah but the cluster I have is scratched up and plus I don't have the original gauges.
Old 09-29-2004, 05:02 PM   #5 (permalink)
LOS
LOS's Avatar
Car: 97 540IA, 95 840CI
Brian325i, a cluster only displays general information, it doesn't store anything. odometer mileage is store in the computer...
LOS
Old 09-29-2004, 07:06 PM   #6 (permalink)
Lol...ok well I'm getting two differen't answers...which one is correct??
Old 09-29-2004, 09:58 PM   #7 (permalink)
325isBaby's Avatar
Car: 2005 330xi
The cluster stores VIN, mileage, SIA data etc...and it is VERY important all these items match your car since they are also stored Redundantly in the LM...if the items do not match it will perminatly illuminate the manipulation dot in the mileage portion of the cluster...you must have the cluster re-programmed to keep this from happening.
Come see me at MySpace
Old 09-30-2004, 09:36 AM   #8 (permalink)
LOS
LOS's Avatar
Just call the parts dept at the dealer.. Usually these guys will answer many of your questions
Good luck
LOS
M5 Cluster in a 540i, will it work? ///Matt 5-Series (E12,E28, E34, E39, E60) 5 10-13-2005 10:26 AM
Instrument Cluster Wiring spinkb 3-Series (E21, E30) 6 03-06-2005 08:39 AM
Instrument cluster removal shaman97 3-Series (E21, E30) 5 07-01-2004 03:13 PM
new instrument cluster. hodges 3-Series (E36) 7 05-30-2003 07:49 AM
