Climate Control Reads Deg C - BMW Forum - BimmerWerkz.com
Old 04-17-2005, 09:11 AM   #1 (permalink)
kvadgama is an unknown quantity at this point
Just installed new climate control and reads temperature in C.
How would I change it so that reads temperature in F?
K
kvadgama is offline   Reply With Quote
Old 04-17-2005, 09:45 AM   #2 (permalink)
2ndclasscitizen's Avatar
2ndclasscitizen is an unknown quantity at this point
I think you press the km/mph button, but I dont know if it depends on the type of OBC.
<img src='http://img.photobucket.com/albums/v225/2ndclasscitizen/martinmkcsig.jpg' border='0' alt='user posted image' />
<span style='font-size:9pt;line-height:100%'>It's better than doing crack.</span>
2ndclasscitizen is offline   Reply With Quote
Old 04-17-2005, 09:51 AM   #3 (permalink)
kmh /mph button only works for bottom unit (ie outside temp, miles/Km etc).
I tried that button (kmh / mph), and it does not change climate control temp from C to F.
Do you think I might have gottan european version. I got it from the dealer here in US.
K
Old 04-17-2005, 10:23 AM   #4 (permalink)
Power Shifting
Cruzin 323is's Avatar
there is a way to change it, i know its in the manaul.. beause i've done it before.. i think u have to hit "set/res" but i am not sure
-SOLD..
R.I.P Fast 6
Old 04-17-2005, 11:58 AM   #5 (permalink)
RallyE36 is an unknown quantity at this point
You most likely have the Canadian version climate control.
They are usually the only ones that come to NA.
As far as I know you cannot change the unit's temperature reading.
You may have to do it through the ECU. I would check with the service department of your local dealer just to make sure.
1996 E36 M44 318i 5sp LSD
Canadian Model
RallyE36 is offline   Reply With Quote
Old 04-17-2005, 12:02 PM   #6 (permalink)
Super Moderator
dutchbmw's Avatar
I think there's no possibility to do that.
BMW '96 M3 (SOLD)
June 2005 Car Of The Month!
Originally Posted by Torque
Old 04-17-2005, 02:49 PM   #7 (permalink)
quality
Delmarco's Avatar
if you have the 6 button OBC or pre-1995 OBC then just hit the C/F button twice....
if you don't have that then get in the habit of multiplying the number you see by 9/5 and adding 32 to get F....
Old 04-17-2005, 03:05 PM   #8 (permalink)
Super Moderator
dutchbmw's Avatar
[snapback]333924[/snapback]
Here's a tool specially made for your problem!
right click save as
BMW '96 M3 (SOLD)
Old 04-17-2005, 03:31 PM   #9 (permalink)
Moderator
Dirty_Tool's Avatar
The unit needs to be encoded by a BMW shop with the factory GT1 or Modic or DIS+ and then after encoding, the temp display can be changed via the path "conversion" in the BMW tester.
DT
DT
Old 04-17-2005, 04:01 PM   #10 (permalink)
quality
Delmarco's Avatar
DT
[snapback]333943[/snapback]
or you could just press the C/F button
Old 04-17-2005, 05:58 PM   #11 (permalink)
Originally posted by Delmarco+Apr 17 2005, 03:01 PM--><div class='quotetop'>QUOTE(Delmarco @ Apr 17 2005, 03:01 PM)</div><div class='quotemain'><!--QuoteBegin-Dirty_Tool@Apr 17 2005, 02:31 PM
DT
[snapback]333952[/snapback]
[/b][/quote]
I have 96 328 and it has NO CF button.
And also getting a habit of multiply 9/5 and add 32 is just too much for my brain.
I'd rather use my butt as the temperature thermometer, LOL.
K
Old 04-17-2005, 07:56 PM   #12 (permalink)
Moderator
Dirty_Tool's Avatar
Originally posted by Delmarco+Apr 17 2005, 01:01 PM--><div class='quotetop'>QUOTE(Delmarco @ Apr 17 2005, 01:01 PM)</div><div class='quotemain'><!--QuoteBegin-Dirty_Tool@Apr 17 2005, 02:31 PM
DT
[/b][/quote]
He obviously doesnt have 1 or he wouldnt be posting. He changed the climate control computer not the time-temperature clock if you read his original post. The only way to change the temp display on the climate control panel is through encoding.
DT
DT
Old 04-18-2005, 10:10 AM   #13 (permalink)
Here's the pic to clarify the unit in question.
I have a feeling that dealer might have to program it.
Thanks
Old 04-18-2005, 11:45 AM   #14 (permalink)
Moderator
Dirty_Tool's Avatar
Um yeah, thats what I've been saying.
DT
DT
Old 04-18-2005, 01:53 PM   #15 (permalink)
I agree with Dirty Tool, the dealership has to do it. The dealership reprogrammed mine after I replaced it. I think they charged me about $150.
Does anyone know if it will rese back to C if you loose/disconnect your battery?
climate control fan speed sanga 5-Series (E12,E28, E34, E39, E60) 4 06-02-2010 11:47 AM
BMW has perhaps the WORST climate control SpeedsterBMW 3-Series (E46, E90) 27 05-03-2010 09:59 AM
Rebuilding your e36 climate control computer 98e36bostonchic OEM Parts 2 10-18-2005 09:09 AM
Climate Control Rookie 3-Series (E36) 9 03-14-2005 11:51 AM
