Climate Control Problem - BMW Forum - BimmerWerkz.com
Old 12-13-2004, 08:27 PM   #1 (permalink)
lxv8 is an unknown quantity at this point
Climate control on my 96 328ic blows cold on the driver side only. the passenger side works fine. anyone know of a possible reason for this? do both sides use the same heater core? if so the only possible reason I can think of is a plumbing problem in the air ducts? any suggestions appreciated....
lxv8 is offline   Reply With Quote
Old 12-15-2004, 11:46 AM   #2 (permalink)
mech9T8's Avatar
mech9T8 is an unknown quantity at this point
Funny because the company I work for makes air ducts for cars.
This is what could be happening. You mentioned that you have a '96 so I assume you have dual zone climate control. In this case 1) the sensor that detects the temperature going to the driver side is malfunctioning. 2) the baffle that mixes the air going to the driver side is stuck. 3) the actuator that controls the baffle is not working.
Hope this helps.
<img src='http://www.geocities.com/royb9t8/MY_BMW_2.jpg' border='0' alt='user posted image' />
<span style='color:blue'>My ass may be dumb, but I ain't no dumb ass!</span>
mech9T8 is offline   Reply With Quote
Old 12-15-2004, 06:14 PM   #3 (permalink)
motown3's Avatar
motown3 is an unknown quantity at this point
[snapback]249706[/snapback]
Sounds like your heater valve is bad. This routes hot water to the core. there is a single valve, but it controls the water on either side.
&quot;Friends may come and go, but enemies accumulate&quot;
motown3 is offline   Reply With Quote
Old 12-15-2004, 10:04 PM   #4 (permalink)
mech9T8's Avatar
No, it's not the valve because he said he is getting heat on the passenger side.
Old 12-15-2004, 11:59 PM   #5 (permalink)
RedlinedRU's Avatar
RedlinedRU is an unknown quantity at this point
Send a message via AIM to RedlinedRU
i think you might have the little selector on cold. under the main vent on the bottom right should be a red/blue selector. if it is on blue, then only cold air will be allowed to come through that vent. it confused me at first all you have to do is turn it to the red and hot air should come out. I hope your problem is this simple to fix......good luck
<span style='color:green'>
AMG can't build an NA engine that can compete with M engines, so they stick in a supercharger and say their cars are faster. BMW could simply do the same, but they don't out of principle.</span>
RedlinedRU is offline   Reply With Quote
Old 12-16-2004, 07:03 PM   #6 (permalink)
No it is not the selector on the middle vent it is on the red side and the air is still cold also the air doesnt come out warm on the other driver vent either. Where can i find the the actutaor and the tempature sensor so that i can diagnose this problem.
Old 12-17-2004, 09:24 AM   #7 (permalink)
mech9T8's Avatar
Don't know for sure.
The temp sensor is somewhere on the duct.
The actuator would be on the HVAC case.
All of that stuff is behind the dash.
Old 12-26-2004, 04:03 PM   #8 (permalink)
I fixed the problem it was the heater control valve for the passenger side was bad. I replaced it and the heat works great now. Thanks for everyones help and suggestions they were much apprecaited.
Old 12-27-2004, 11:23 AM   #9 (permalink)
mech9T8's Avatar
The heater control valve on the passenger side?
That's weird because you said you said the passenger side was working.
Well at least you got it fixed. Did you do it yourself? If so it would be nice if you wrote up a DIY for other members on this forum.
climate control fan speed sanga 5-Series (E12,E28, E34, E39, E60) 4 06-02-2010 11:47 AM
BMW has perhaps the WORST climate control SpeedsterBMW 3-Series (E46, E90) 27 05-03-2010 09:59 AM
Rebuilding your e36 climate control computer 98e36bostonchic OEM Parts 2 10-18-2005 09:09 AM
Climate Control Rookie 3-Series (E36) 9 03-14-2005 11:51 AM
E39 Climate Control problem jljimenez 5-Series (E12,E28, E34, E39, E60) 3 09-04-2003 10:57 AM
