| I appologize for this question, but you are checking the left most vent when you are checking the drivers side knob correct? Because the middle is controled by the knob underneath the middle part.
It sounds like it could be a heating valve, I'm not exactly sure which part they are reffering to, but usually when this happens with any car, it is just the "flume" like thing that controls whether the air is coming from the heater or from the AC. If that is what they meant by heater valve, then they are most likely correct. |
