| clean injectors need OTC adaptor I am going to clean the injectors on my '97 318IC M44 1.9L 150K. I will use the OTC 7448 canister to clean them on the car. My question is about hooking up to the fuel rail. The OTC uses a quick connector at the end of the hose and requires an adaptor to attach to the fuel rail. Has anyone done this and can you tell me where I can get an adaptor? Is the fitting the same on some other makes (Ford, Chev?) that might be easier to find? If I can make this work I will do my Z4 and my X3. Are the fuel rail hookups the same on all of these?
Thanks in advance, Any help will be appreciated. |
