Check Engine Light (fuel injector) - BMW Forum - BimmerWerkz.com
Old 05-08-2009, 02:11 AM   #1 (permalink)
acid86's Avatar
Car: 1992 Bmw 318is (e36)
acid86 is on a distinguished road
Send a message via MSN to acid86 Send a message via Yahoo to acid86
Angry Check Engine Light (fuel injector)
HI. I have a '92 318is and i recently (tonight) changed one of my fuel injectors. well, the engine runs fine, better actually, but the problem is that the check engine light is on. it's not flashing, no intermittent light, just on, solid.
the car runs fine like i said, but i need help. what should i do to fix it, and what exactly could it be?
thanks for your help. if you need any more information just comment.
**update** ok, so the light goes off at high rpm and comes back on when the rpm's go back down. dunno if it will make a difference, but the more info the better.
on another note. the obd 1 doesn't seem to yeild anything. "turn the key to the on position and press the accelerator 5 times before 5 seconds and you'll get a code..." well, no. the light just stays on.
"I know not with what weapons World War III will be fought, but World War IV will be fought with sticks and stones." - Albert Einstein
acid86 is offline   Reply With Quote
Old 05-08-2009, 04:12 AM   #2 (permalink)
Help from over the pond
marti5's Avatar
Car: E38 1997 728i Individual
Try disconnecting the battery for 30 minutes, if you have a coded radio make sure you have the code.
Old 05-08-2009, 06:52 AM   #3 (permalink)
MADDOUG is on a distinguished road
I have seen a post on another forum a while ago concerning an e34 tds that did the same thing with the light coming on just over tickover at about 2k revs and then going off at or near red line.This was put down to the injector pumps static timing being timed up wrong,the ecu ran out of scope on its inbuilt maps to control the pumps advance retard so it lit up the warning lamp.
MADDOUG is offline   Reply With Quote
Old 05-08-2009, 08:26 PM   #4 (permalink)
acid86's Avatar
did the thread ever figure out how to solve it?
and i tried the batt terminal thing, didn't work.
any other ideas?
Old 05-09-2009, 03:58 PM   #5 (permalink)
Yes the owner had the codes read before he posted 'fuel range out of calibration' I recall was what the code reader came up with.It was a site for running veg oil as fuel so someone had an answer straight away to the problem,most who run veg alter their pump timing by moving the pump.I find it strange yours still runs ok with the light on,no going into 'limp mode' and losing power or running rough ?
Old 05-10-2009, 01:30 AM   #6 (permalink)
acid86's Avatar
no none, what so ever. the light however, is being rather finiky, sometimes it's a constant light and others, it goes off if the rpms are high, and even stranger, sometimes, the light will go off if i barely touch the gas.
also i was wondering if there is anything im' doing wrong with the odb I diagnostic. i put the key to the on position and i pump the gas 5 times to the floor within 5 seconds but no codes display. i suppose if i can figure that out, then maybe it'll be easier to diagnose what exactly is wrong. maybe i'm missing something. i tried taking everything i had apart and making sure that everything was correct. still, the light stayed on. however! i did notice that the new fuel injector had something different than the rest. the spray nozzle had a different order, or stack up if you will. it went "nozzle, rubber o ring, plastic washer, and then the rest of the injector" when the rest of the injectors had the plastic washer and o ring reversed. i tried to slide the o ring over the washer but, no dice.
any thoughts?
Old 05-15-2009, 04:35 AM   #7 (permalink)
vegetableoildiesel.co.uk - replace one injector... or replace them all ? - Powered by XMB It may be the injector you fitted is wrong type so presuming your cars ecu can pick it up that may be the cause of the light.Have a read of the posts in the link above,one post mentions how ecu monitors feedback from each injector.
Fuel Check light & no acceleration fester001 5-Series (E12,E28, E34, E39, E60) 2 12-24-2008 02:51 PM
Check Light And Check Engine Light 325is1994 3-Series (E36) 9 01-12-2005 01:36 PM
Check Engine Light & Air Bar Light blackstallion 3-Series (E36) 1 11-11-2004 11:53 AM
loud engine noise and check engine light steviebhoy 3-Series (E36) 4 06-04-2004 06:59 AM
check engine light and check light Scarface 3-Series (E36) 3 06-03-2003 08:31 AM
