Check Engine Light came on today - BMW Forum - BimmerWerkz.com
Old 05-14-2004, 11:41 AM   #1 (permalink)
camnipotent's Avatar
camnipotent is an unknown quantity at this point
Send a message via AIM to camnipotent Send a message via MSN to camnipotent
My check engine light came on today. It's only orange so I should be okay to drive. I checked in my owners manual and it said the check engine light comes on and that it is because of some part of the emissions sensors. Should I be worried? I have a call into the local BMW retailer to get it checked soon.
<span style='font-size:8pt;line-height:100%'><span style='color:blue'>1998 BMW 323is Coupe, Black
Manual
18&quot; M3 Hyper Silver Rims
2 12&quot; Rockford Fosgate Subs; Sealed
1.0 Farad Capacitor
800 Watt 2-Way Rockford Fosgate Amplifier</span></span>
camnipotent is offline   Reply With Quote
Old 05-14-2004, 12:03 PM   #2 (permalink)
jack cass is an unknown quantity at this point
Mine came on this week too. Go to an Auto Zone and ask them to read out the codes from your OBDII. This will tell you what the problem may be. I think mine turned out to be just an oxygen sensor failure. I've ordered some new ones and I'm going to install next week.
Anyway, go to Auto Zone and have them read your OBDII for free, then come tell us what it says. Then someone else can help you from there, as I'm a new owner myself and this is the first time I'm working through the same problem too.
--jack
jack cass is offline   Reply With Quote
Old 05-14-2004, 12:46 PM   #3 (permalink)
Thanks man. I'll let you know soon.
Manual
1.0 Farad Capacitor
Old 05-14-2004, 01:29 PM   #4 (permalink)
CiscoKid's Avatar
usually its an oxy sensor... my friend had that error when he dindt have a sensor vbecase they had to order them
Old 05-14-2004, 01:47 PM   #5 (permalink)
TeeUp's Avatar
Car: 2002 X5 3.0i and 2007 X5 3.0i
TeeUp is an unknown quantity at this point
same here...
friends in this forum said that for as long as you dont have that rotten egg smell then it is more likely your oxygen sensor and not your $700 or so catalytic converter.
i dont know what your car is but if it is a 1996 or later model then you must have an OBDII which AutoZone can check for free. i heard it somewhere that they cannot do it on an OBDI. also, it would have two O2 sensors one before the cat and another after. AutoZone sells a bosch before cat sensor for $61.xx (plus $6 S&H) which is the cheapest i asked (sold online for $95). their after cat sensor is $138.xx. you'll be better off ordering online for $124.xx with free shipping.
TeeUp is offline   Reply With Quote
Old 05-14-2004, 01:49 PM   #6 (permalink)
TeeUp's Avatar
oh, before i forget. check engine light turns on too if you have a loose gas cap or oil filler cap. this is US regulation requirement to ensure none of our cars evaporate harmful substances to our air.
Old 05-14-2004, 02:27 PM   #7 (permalink)
Nice work guys. I am leaving right now to go have Autozone check it out for me.
Manual
1.0 Farad Capacitor
Old 05-14-2004, 02:31 PM   #8 (permalink)
Car: 2008 128i
Let us know.
2008 128i Jetblack
Old 05-14-2004, 03:18 PM   #9 (permalink)
Okay, here's the deal. The fault code is P1423. What that means, I don't know. Maybe you guys can help. The thing is, the readout on the diagnostic computer says Auxillary emissions control, manufacturer. In other words, it's not telling us the problem other than it is emissions related. I am going to have to find out through you guys, or the dealer. If you guys can find out, that would be awesome. The dealer here is huge and respected, but they don't return phone calls worth a damn.
Manual
1.0 Farad Capacitor
Old 05-14-2004, 04:11 PM   #10 (permalink)
this was posted on another forum. i'll just copy it in here and not say where it's from... don't want to the moderator to get upset at me for drawing others away from this forum : - )
your code P1423 is almost at the end. unfortunately, this is all the help i can provide. hopefully someone else out there knows how to fix this problem.
Oxygen Sensor Monitoring for the M52 engine only.
P0130 - O2 Sensor Circuit (bank 1, sensor 1)
P0150 - O2 sensor circuit (bank 2, sensor 1)
P0136 - O2 sensor circuit (bank 1, sensor 2)
P0156 - O2 sensor circuit (bank 2, sensor 2)
P0134 - 02 sensor circuit (bank 1, sensor 1) open
P0154 - O2 sensor circuit (bank 2, senso 1) open
Oxygen Sensor Heater Circuit for the M52 engine only.
P0135 - O2 sensor heater circuit (bank 1, sensor 1)
P0150 - O2 Sensor heater circuit (bank 2, sensor 1)
P0141 - 02 sensor heater circuit (bank 1, sensor 2)
P0161 - O2 sensor heater circuit (bank 2, sensor 2)
P1186 - O2 sensor heater circuit (bank 1, sensor 2)
P1187 - O2 sensor heater circuit (bank 2, sensor 2)
Switch and response time monitoring for M52 engine only.
P1178 - O2 switch time (bank 1, sensor 1)
P1179 - O2 switch time (bank 2, sensor 1)
P0133 - O2 sensor control frequency (bank 1, sensor 1)
P0153 - O2 sensor control frequency (bank 2, sensor 1)
Catalyst Monitoring for M52 engine only.
P0420 - Catalyst Efficiency Bank 1
P0430 - Catalyst Efficiency Bank 2
Misfire detection Faults
P0301 - Misfire Cylinder 1
P0302 - Misfire Cylinder 2
P0303 - Misfire Cylinder 3
P0304 - Misfire Cylinder 4
P0305 - Misfire Cylinder 5
P0306 - Misfire Cylinder 6
Evaporative System Monitoring for M52 TLEV Vacuum type only.
P0440 - Purge Function Plausibility
P0442 - Small leak detected
P0441 - no purge flow detected
P0446 - shut off valve stuck closed
P0445 - Large leak detected
P0440 - Purge valve stuck open
P0451 - fuel tank pressure sensor range and performance
P1403 - Evap Canister shut off valve and circuit
P0443 - Purge valve and circuit.
Secondary Air Injection Monitoring for M52 engines only.
P1453 - Secondary air pump electric pump.
P0412 - Secondary switching valve.
P1423 - Secondary air injection system bank 1
P1424 - secondary air injection system bank 2
Fuel System Monitoring for M52 engines only.
P1188 - Mixture deviation cylinder 1-3
P1189 - Mixture deviation cylinder 4-6
Old 05-14-2004, 04:24 PM   #11 (permalink)
Super Moderator
dutchbmw's Avatar
We all keep it quiet.....
BMW '96 M3 (SOLD)
June 2005 Car Of The Month!
Originally Posted by Torque
Old 05-14-2004, 05:40 PM   #12 (permalink)
What t he hell is that? Damn it. I guess I'll find out soon....
Manual
1.0 Farad Capacitor
Old 05-14-2004, 06:11 PM   #13 (permalink)
Defector
El Presidente's Avatar
HOW DARE YOU POST INFO FROM ANOTHER SITE!!!
ONE MORE TIME AND YOUR BANISHED!
Old 05-14-2004, 06:13 PM   #14 (permalink)
Defector
as for secondary air injection, no clue.
Doesn't sound important though, or it wouldn;t be seconday. I'd look for something loose or frayed bu the intake.
Old 05-16-2004, 04:39 PM   #15 (permalink)
TeeUp's Avatar
you can actually go back to autozone (sorry for not letting you know earlier, i thought they would do this as a matter of course). they have this book for you to see (and probably take notes from) as to the possible causes of the code you got.
it will make you understand the fault better than just telling you its the effect - which is "Auxillary emissions control, manufacturer" it will list down possible causes like: O2 sensors fault, indication that gas cap is loose, etc...
Check Engine Light Turned On... Turbodefrost 3-Series (E36) 23 03-29-2005 02:09 AM
Check Engine Light BlantonG13 3-Series (E36) 15 01-04-2005 08:46 AM
Inspection I iantosca 3-Series (E36) 5 09-18-2004 12:18 AM
check engine light leobmw 5-Series (E12,E28, E34, E39, E60) 4 11-28-2003 03:55 PM
Question about the check engine light. jdwango 3-Series (E36) 4 10-10-2003 10:51 AM
