CHECK ENGINE LIGHT CAME ON - BMW Forum - BimmerWerkz.com
Old 06-05-2004, 12:14 AM   #1 (permalink)
99bimmer is an unknown quantity at this point
engine light came on on my 93 325is took to get fault code read said it was 02 sensor ok so i got a new one put in...they also said there was a stored fault code for my knock sensors (what does that do???) but was told it shouldnt be a problem well check engine light isnt on till i was driving to work the next day and it came back on then later that night on the way home it went off.should i look into y my check engine light did that or was it a glitch...also what should my rmps be at idle cause there just alittle over 500 is that normal or should it be higher....any suggestions on whats going on thanks....Ben
99bimmer is offline   Reply With Quote
Old 06-05-2004, 12:34 PM   #2 (permalink)
Bengali86's Avatar
Bengali86 is an unknown quantity at this point
Send a message via MSN to Bengali86
Ok, this is strange,
My name is Ben, i have a 93 325is too... I had my engine light come on, it was my O2 sensor too. i had it replaced, a couple of days later,my car was still acting strange (engine light was on again) RPMs would bounce up and down, i took it back in, they said they gave me a faulty O2 Sensor, so they replaced it again, also my #2 Knock sensor was down, so i had both replaced (sensor #1 and #2) what they do is when they sense Knocking/pinging they adjust the valves (?) correct me if i am wrong.. thats the self adjusting valves, the '93 M50 engines have a different fuel injection system and knock sensor system than the '94+ models
healthy RPMs for you car is betwen 500-700 rpms at idle
cool car and cool name Ben
~Ben
1993 e36 325is
AC Schnitzer Exhaust
AC Schnitzer type I full body kit
AC Schnitzer chip
A monkey in the trunk (stock)
Dual V-Tec
Bengali86 is offline   Reply With Quote
Old 06-06-2004, 01:32 AM   #3 (permalink)
hey thanks for the response and thats wierd we have same name and car.....so about how much money would both knock sensors be if they do become a problem cause everything seems fine on the car i guess since the check engine light went off and the rmps are right....plus how do u like the ac stuff on ur car hp gains and prices...Ben
Check Engine Light aheath 3-Series (E36) 1 04-27-2005 06:27 PM
Check Engine Light On, But Only When I Start Car BMW-ATI 3-Series (E36) 5 04-15-2005 09:40 PM
Check Engine Light & Air Bar Light blackstallion 3-Series (E36) 1 11-11-2004 11:53 AM
Red check engine light came on today YNGRVP 3-Series (E36) 9 05-28-2004 09:36 PM
Check Engine Light came on today camnipotent 3-Series (E36) 22 05-17-2004 06:23 PM
