Originally Posted by 318itx ok i had this problem earlier and wanted to look to see what was causing it..because the damn check engine light is turning off and on. its like every few days that it turns on..
the code i got was: P0340
the code says it is a malfuntion in the electrical circuit for the camshaft position sensor( it says "bank 1 identifies the location of Cylinder #1)
now..if it keeps turning off and on..what could that be here were the "possiblities"
1. cam sensor defective
2. connector/wiring defective
3. Engine running condition- timing belt out of time
now i am kind of hearing a noise coming from my engine and so maybe the belt is off somewhat? my idle is speratic and i don't want to see this check engine light anymore lol. any suggestions before i take it to the dealership? anyone else have this problem |
I have a 98 323is m52, well it was thowing the same code p0340 and p1519 which are codes for camshaft p sensor, of course you new that already, well if you know someone who works for bmw buy the part threw them. Quoted without the friend $143, with the friend $67. Cant beat that. Do the work yourself, hopefully you have small hands or one of your friends do...
. It will take you about an hour.... I changed mine on saturday...
