Check Engine Light - BMW Forum - BimmerWerkz.com
Old 07-05-2005, 11:52 PM   #1 (permalink)
E36 325I's Avatar
E36 325I is an unknown quantity at this point
Send a message via AIM to E36 325I
i have a 92 325i. While i was making a left hand turn the check engine light came on. I am wondering if it could be that my coolant is low. Could the check engine light be on becuase of low coolant?
E36 325I is offline   Reply With Quote
Old 07-05-2005, 11:59 PM   #2 (permalink)
my car is red
94BMW325i's Avatar
Car: 94 325i, 84 325e
Actually it could be on for a few different reasons. Do you have a tool to check waht the problem is? If not I think places like Autozone, pep boys will do it for free?
Old 07-06-2005, 12:32 AM   #3 (permalink)
cymorg's Avatar
cymorg is an unknown quantity at this point
Send a message via ICQ to cymorg Send a message via AIM to cymorg Send a message via MSN to cymorg Send a message via Yahoo to cymorg
advanced auto parts will do it and for free
i just had it done today!
cymorg is offline   Reply With Quote
Old 07-06-2005, 07:46 AM   #4 (permalink)
93 325i's Avatar
Since your car is a 92 you can read the codes directly from the car. Go to ultimate-bmw.com and look for the fault codes DIY. THe check engine light will not go on because of coolant tho. The check engine light is an emissions related fault. 9 times out of 10 a check engine light means O2 sensor. There are many other reasons it would come on, but O2 sensor is most common..
Complete mod list and pics:
My 1993 325i
Old 07-06-2005, 10:29 AM   #5 (permalink)
aheath's Avatar
aheath is an unknown quantity at this point
Send a message via AIM to aheath
could be many reasons why your check engine light came on. A month ago my check engine light came on because my gas cap was only 3/4ths of the way on.
aheath is offline   Reply With Quote
Old 07-06-2005, 05:06 PM   #6 (permalink)
E36 325I's Avatar
Thanks guys. Im a new owner of this car so im still learning about them. Definetly will check out advanced auto parts. Im sure you will be hearing from me again.
Old 07-06-2005, 07:28 PM   #7 (permalink)
funtoos's Avatar
funtoos is an unknown quantity at this point
Send a message via AIM to funtoos
i have the same car... when my coolant was low, the obd gave me an error saying that coolant was low... have autozone read the code for you for free...
'04 330Ci
'00 Kawasaki ZX9-R
Now looking for an M3
funtoos is offline   Reply With Quote
Old 07-07-2005, 08:28 AM   #8 (permalink)
93 325i's Avatar
[snapback]360035[/snapback]
Also he may not have the 18 button OBC. In that case he wont have a "check" feature that tells the coolant is low..
My 1993 325i
Old 07-20-2005, 04:46 AM   #9 (permalink)
Dudesky_E36's Avatar
Car: Anthracite e39 530iA
Dudesky_E36 is an unknown quantity at this point
Send a message via AIM to Dudesky_E36
You sure about this? My check engine light came on yesterday, and the OBC read "Washer Fluid Low". But it only came on momentarily. The check control cleared up once I added more fluid. But it happened as I was making a turn, so this could be the original poster's problem. The fluid was right at the fill mark, so turning caused the sensor to trigger.
Dudesky_E36 is offline   Reply With Quote
Old 07-20-2005, 05:22 AM   #10 (permalink)
NESS is an unknown quantity at this point
Most Autozones and Advance Auto Parts will not read codes for OBD-1 cars only OBD-2.
NESS is offline   Reply With Quote
Old 07-20-2005, 08:30 AM   #11 (permalink)
93 325i's Avatar
Originally posted by Dudesky_E36+Jul 20 2005, 04:46 AM--><div class='quotetop'>QUOTE(Dudesky_E36 @ Jul 20 2005, 04:46 AM)</div><div class='quotemain'><!--QuoteBegin-93 325i@Jul 6 2005, 07:46 AM
[snapback]363727[/snapback]
[/b][/quote]
The light you are refering to is not the CHECK ENGINE light. You are talking about the CHECK light. This yellow light informs you that there is a fault on your OBC. The CHECK ENGINE light is red and has nothing to do with your OBC.. Again, there are two seperate lights..a yellow CHECK light and a red CHECK ENGINE light..
My 1993 325i
Old 07-20-2005, 09:05 AM   #12 (permalink)
Gator is an unknown quantity at this point
How did it happen? Disregard Brain fade,posted to wrong topic.
Gator is offline   Reply With Quote
Old 07-20-2005, 07:01 PM   #13 (permalink)
[snapback]363747[/snapback]
[/quote]
Ahh, got it. My bad ghead
Old 07-20-2005, 07:09 PM   #14 (permalink)
Avlany's Avatar
Avlany is an unknown quantity at this point
Send a message via ICQ to Avlany
Your computer should give you an explanation if you press CHECK button, if its your coolant level, it should say so.
Dont piss me off. I am running out of places to hide the bodies
<img src='http://members.dslextreme.com/users/avlany/images/BMW%20banner.gif' border='0' alt='user posted image' />
Avlany is offline   Reply With Quote
Old 07-21-2005, 08:14 AM   #15 (permalink)
WarNox's Avatar
Originally posted by Dudesky_E36+Jul 20 2005, 03:46 AM--><div class='quotetop'>QUOTE(Dudesky_E36 @ Jul 20 2005, 03:46 AM)</div><div class='quotemain'>
[/b]
i swear we have the same car, mine did this exact same thing the other day!
[/quote]
ok let me try to get this right:
Yellow: little problems like water level low, break light failure etc
Red: bigger engine probs, o2 sensor...etc
right or wrong?
thnx
<img src='http://www.geocities.com/thereisnothinglikeabmw/mycar1.jpg' border='0' alt='user posted image' />
WarNox is offline   Reply With Quote
Check Engine Light aheath 3-Series (E36) 1 04-27-2005 06:27 PM
Check Engine Light On, But Only When I Start Car BMW-ATI 3-Series (E36) 5 04-15-2005 09:40 PM
Check Engine Light & Air Bar Light blackstallion 3-Series (E36) 1 11-11-2004 11:53 AM
Red check engine light came on today YNGRVP 3-Series (E36) 9 05-28-2004 09:36 PM
Check Engine Light came on today camnipotent 3-Series (E36) 22 05-17-2004 06:23 PM
