Check Engine Light - BMW Forum - BimmerWerkz.com
post #1 of 10 (permalink) Old 06-29-2005, 01:30 PM Thread Starter
spotteddog is an unknown quantity at this point
I have a 328i 1997: the check engine light came on a few days ago. What does it really mean? The owners manual says it's something to do with emission gear and needs to be checked by dealer...immediately. What triggers the light to come on? Is it milage? something in the fuel system?
spotteddog is offline
post #2 of 10 (permalink) Old 06-29-2005, 01:48 PM
aheath's Avatar
aheath is an unknown quantity at this point
Send a message via AIM to aheath
Is your gas cap fully closed? I had my gas cap on 3/4th's of the way and my check engine light came on.
Check this and if this does not work then go to Autozone and ask them to pull the codes.
aheath is offline
post #3 of 10 (permalink) Old 06-29-2005, 02:25 PM
napalm is an unknown quantity at this point
[snapback]358321[/snapback]
Good suggestion, just another bit of information I have..
I changed my o2 Sensor in my exhaust and eliminated the check engine light in my 95 325iC.
Its an inexpensive part (mine was anyway).
Good luck hope you find the problem.
napalm is offline
post #4 of 10 (permalink) Old 06-29-2005, 04:35 PM
Auto Aone or Advance can code it for FREE.
Bear is offline
post #5 of 10 (permalink) Old 07-01-2005, 11:12 AM Thread Starter
Autozone will run the codes.... IF the tech can find the computer-connection port. On a 328, where is the connection port? Engine bay? under the dash? I've looked around but cannot find something obvious to connect to. The Autozone connection was a small trapazoid-shaped plug.
post #6 of 10 (permalink) Old 07-01-2005, 12:36 PM
kestrel325is's Avatar
kestrel325is is an unknown quantity at this point
The OBDII connection on a 328 is under the dash, near the hood release lever.
kestrel325is is offline
post #7 of 10 (permalink) Old 07-03-2005, 01:01 AM
cymorg's Avatar
cymorg is an unknown quantity at this point
i just had the same problem tonight, with my check engine light coming on.
where is this plug thing on a 318?
cymorg is offline
post #8 of 10 (permalink) Old 07-03-2005, 09:34 AM
quality
Delmarco's Avatar
Delmarco has a reputation beyond repute Delmarco has a reputation beyond repute Delmarco has a reputation beyond repute Delmarco has a reputation beyond repute Delmarco has a reputation beyond repute Delmarco has a reputation beyond repute Delmarco has a reputation beyond repute Delmarco has a reputation beyond repute Delmarco has a reputation beyond repute Delmarco has a reputation beyond repute Delmarco has a reputation beyond repute
if you have a pre-1996 E36....
1. turn the ignition on (not the engine, just the ignition)
2. wait for the dash lights to come on
3. quickly press and release-all the way up the gas pedal 5 times and look at the "Check Engine Light"
4. It will flash several times, like morse code, and will tell you 4 numbers, all ranging between 1 and 4 (for ex. 1134)
5.these numbers are code for what is wrong specifically with the engine and car.
Delmarco is offline
post #9 of 10 (permalink) Old 07-03-2005, 12:21 PM
cymorg's Avatar
mine's a 96 though
cymorg is offline
post #10 of 10 (permalink) Old 07-06-2005, 09:58 PM Thread Starter
Went to AdvancedAuto and they ran the codes. The computer port is under dash near hood release. (328i...'97). The cover plate comes undone with the twist of a slotted fixture. Check engine light may be linked to gas cap, this time. Clerk/tech at AdvancedAuto reset the stuff and the light is now off. This forum is a GREAT place to get info. Thanks!
Check Engine Light came on today camnipotent 3-Series (E36) 24 08-08-2014 06:20 AM
Check Engine Light aheath 3-Series (E36) 1 04-27-2005 07:27 PM
Check Engine Light On, But Only When I Start Car BMW-ATI 3-Series (E36) 5 04-15-2005 10:40 PM
Check Engine Light & Air Bar Light blackstallion 3-Series (E36) 1 11-11-2004 12:53 PM
Red check engine light came on today YNGRVP 3-Series (E36) 9 05-28-2004 10:36 PM
