Check Engine Light - BMW Forum - BimmerWerkz.com
Old 03-30-2005, 09:15 AM   #1 (permalink)
hoodjr is an unknown quantity at this point
Does anyone know how to reset the check engine light on a 323is without the tool? I figured out what pins to cross to reset the oil and service lights. I would appreciate any help I can get. Thank you.
hoodjr is offline   Reply With Quote
Old 03-30-2005, 09:21 AM   #2 (permalink)
aheath's Avatar
aheath is an unknown quantity at this point
Send a message via AIM to aheath
[snapback]321495[/snapback]
I cut a small piece of speaker wire off (2-3-inches) and used that. Just make SURE that you're poking the right hole. 10 secs- to reset service light 3 secs- to reset oil light.
I know there's several DIY's in this forum in regards to this as well.
*disclaimer* do this at your own risk
aheath is offline   Reply With Quote
Old 03-30-2005, 09:58 AM   #3 (permalink)
I know to use pins 7 and 19 for the oil and service indicators but I just changed out the secondary air pump and pump control valve and the check engine light never went off. I was told to purchase a device that would reset the check engine light. However I don't want to spend the $138 for a device that I don't need. Do you know what pins to cross to reset the check engine light? Thank you.
Old 03-30-2005, 10:24 AM   #4 (permalink)
pcy
pcy is an unknown quantity at this point
Go to AutoZone, if one is located around where you live.
They will read the code and RESET for FREE.
OR
You can wait for few more days and it will reset [by itself] after 40 on/off cycles.
Yes, it will reset itself. The car would have to go through 40 or so cycles with no errors.
Good Luck
pcy is offline   Reply With Quote
Check Engine Light aheath 3-Series (E36) 1 04-27-2005 06:27 PM
Check Engine Light On, But Only When I Start Car BMW-ATI 3-Series (E36) 5 04-15-2005 09:40 PM
Check Engine Light & Air Bar Light blackstallion 3-Series (E36) 1 11-11-2004 11:53 AM
Red check engine light came on today YNGRVP 3-Series (E36) 9 05-28-2004 09:36 PM
Check Engine Light came on today camnipotent 3-Series (E36) 22 05-17-2004 06:23 PM
