Check Engine - BMW Forum - BimmerWerkz.com
Old 12-28-2004, 10:48 AM   #1 (permalink)
Black318IS is an unknown quantity at this point
ok, so i go and spend 500$ on new tires today and come home. i parked my car and left about an hour later and now my check engine light is on. i have no clue what it could be. does anyone have any ideas? i need to fix this
Black318IS is offline   Reply With Quote
Old 12-28-2004, 12:53 PM   #2 (permalink)
350z
Car: 03 Nissan 350z Track
hmm well its not your new tires! hahaha, anyways theres somany possibilities of what it could be check engine light could be anything!! is your car making any weird noises, not running right etc? it could just be a sensor you should get it hooked up to a diagnostic.. but that is $$$
David
**BAKER POW REPORT**
Old 12-28-2004, 12:53 PM   #3 (permalink)
350z
oh yeah do you have like an aftermarket exhuat or anything? things like that can throw a code sometimes
David
Old 12-28-2004, 02:41 PM   #4 (permalink)
agtur2001's Avatar
Car: 1994 325ic
agtur2001 is an unknown quantity at this point
When my engine light turned on in my 318is, the code pointed towards my alternator. I replaced the Voltage Regulator and it's fine now. Run the Diag first and get the code.
agtur2001 is offline   Reply With Quote
Old 12-28-2004, 02:47 PM   #5 (permalink)
350z
yeah my alternator has gone out twice in my other e36 and both times the check light would come on, but just like 30 min before my car would lose all power and die completely. my abs light along with others would come on too... the onyl way you will realyl find out is to hook it up to a diagonstic
David
Old 12-28-2004, 02:59 PM   #6 (permalink)
24valve's Avatar
Car: 1994 SAAB 9000 Aero
24valve is just really nice24valve is just really nice24valve is just really nice24valve is just really nice24valve is just really nice
Send a message via AIM to 24valve
David
[snapback]259664[/snapback]
That's not true. The "Check Engine" light only comes on when there's an emissions related matter amiss - for example, a problem with the catalytic converter or oxygen sensors.
Go to Advance Auto Parts and have your codes scanned for free, then come back here and these guys should be able to tell you what to do. It could just be that you need to replace a sensor, etc.
<img src='http://www.pitt.edu/~sjc22/sig3.jpg' border='0' alt='user posted image' />
Member of the &quot;I haven't passed a cop at 115 mph or drifted on a neighborhood street to impress a girl because I'm not a fucking idiot&quot; club
24valve is offline   Reply With Quote
Old 12-28-2004, 03:21 PM   #7 (permalink)
350z
didnt i say its probably just a sensor? haha
David
Old 12-28-2004, 03:33 PM   #8 (permalink)
BlantonG13's Avatar
BlantonG13 is an unknown quantity at this point
Send a message via AIM to BlantonG13
anything after late 95 can have so many other reasons than just emissions...do a forum search and check out the results from the user "Furious" because I am dealing with the same check engine light problem. My car is a 96, so I have to have it Diag'd
1996 318i
5 Speed Manual
Alpine CDA-7895 Head Unit
12&quot; Alpine Type-R, sealed box
Infinity Kappa 4&quot; 2-way speakers(rear)
Infinity Kappa 5.25&quot; component speakers(front)
Debaffled airbox, K&amp;N filter
Tracked Mud on carpets
Shampooed and cleaned carpets
BlantonG13 is offline   Reply With Quote
Old 12-28-2004, 03:44 PM   #9 (permalink)
agtur2001's Avatar
Car: 1994 325ic
Before I replaced my Voltage Regulator... I had to replace my Oxygen Sensor as well.
Found codes here.
http://www.unofficialbmw.com/repair_faqs/motronic.html
Hope this helps... Good Luck!
used
Old 12-30-2004, 12:44 AM   #10 (permalink)
I just realized that my inspection bars have gone all the way done and it now says it need an inspection. If i were to reset that, would that posssibly take the light off?
Old 12-30-2004, 09:15 AM   #11 (permalink)
Deloriant's Avatar
Deloriant is an unknown quantity at this point
Send a message via AIM to Deloriant
Gas cap on tight?
<img src='http://i116.photobucket.com/albums/o17/M4yorThis/119575444991686.jpg'>
Deloriant is offline   Reply With Quote
Old 12-30-2004, 10:09 AM   #12 (permalink)
-pimpin328is-'s Avatar
-pimpin328is- is an unknown quantity at this point
[snapback]259749[/snapback]
not on my car at least, my check light come on for tons more than just emissions related matters. My check engine light is on right now for low coolant, and low washer fluid.
Mods: Tint, Euro Tails, Smoked corners and Side Markers, E46 Style Shadow Grill, 18&quot; M3 Replicas, M3 Exhaust, Low Beam Silver Stars
-pimpin328is- is offline   Reply With Quote
Old 12-30-2004, 10:14 AM   #13 (permalink)
drz
master of his domain
drz's Avatar
Car: zhp
[snapback]260791[/snapback]
Sure, you can try that. But I would still take it to Autozon or Advanced Auto parts to get the code read. It's free! Then someone here will tell you what to do about it. Go do it... right now!! Just kidding.
Turkey Fleet Bond Holder
Old 12-30-2004, 02:32 PM   #14 (permalink)
350z
i have had my inspection light on for a year on my other e36 check engine never came on cause of it
David
Old 12-30-2004, 04:45 PM   #15 (permalink)
24valve's Avatar
Originally posted by -pimpin328is-+Dec 30 2004, 10:09 AM--><div class='quotetop'>QUOTE(-pimpin328is- @ Dec 30 2004, 10:09 AM)</div><div class='quotemain'><!--QuoteBegin-24valve@Dec 28 2004, 02:59 PM
[snapback]260937[/snapback]
[/b][/quote]
Check Control maybe, but not Check Engine. Manual says word for word that the small check engine light in the gauge console relates to emissions only.
Buying 1997 Bmw 318i - Need Your Help! newbmw 3-Series (E36) 7 09-06-2005 08:04 PM
check engine maru 3-Series (E21, E30) 0 08-23-2004 07:55 PM
service questions thamindzzeye 3-Series (E36) 4 04-30-2003 02:40 PM
