Check Coolant Level problem. - BMW Forum - BimmerWerkz.com
Old 12-14-2003, 04:24 AM   #1 (permalink)
alienbust is an unknown quantity at this point
Hi, my car is a 94 325is. Sometimes when I turn on and turn off the car, the computer displays "check coolant level, see owner's manual", I checked the coolant level and it's about normal, and I don't have an owner's manual. The computer also displays "washer fluids low" when it's not low at all. Anybody know where the problem is?
thanks!
alienbust is offline   Reply With Quote
Old 12-14-2003, 05:50 AM   #2 (permalink)
Turbotec is an unknown quantity at this point
a common problem with the coolant issue, is the float at the bottom of your overflow res, gets gummed up, and cant freely float around. so the fix is either take out that float and clean it up, or buy a new float. the float sensor is cheap and you can buy it on www.bavauto.com. probably the same problem with your washer res.
Turbotec is offline   Reply With Quote
Old 12-14-2003, 05:54 AM   #3 (permalink)
the///man is an unknown quantity at this point
mine does it too now but i think its just due to the cold weather
the///man is offline   Reply With Quote
Old 12-14-2003, 03:22 PM   #4 (permalink)
whitebeemer328 is an unknown quantity at this point
did u just buy this car or its just started to do that.sumtimes in front collision shity body guys plu things in wrong or forget too check all the wires u never know maybe a bad sensor
whitebeemer328 is offline   Reply With Quote
Old 12-15-2003, 02:18 AM   #5 (permalink)
Chooch is an unknown quantity at this point
did you at any point actually ADD coolant to the reservoir ... it may LOOK ok but may actually be low ... add coolant first then revisit ...
<span style='color:blue'><span style='font-family:Arial'>If I try to be like everyone else, who's going to try and be like me?</span></span>
<span style='color:blue'><span style='font-family:Arial'>Mi casa no es su casa, hijo de puta.</span></span>
Chooch is offline   Reply With Quote
Old 12-15-2003, 02:42 PM   #6 (permalink)
BMWChicago is an unknown quantity at this point
aahhhh onboard computers
A friend of mine had an Audi that displayed "Check coolant" and when he added Steering fluid, the signal disappeared
A year later, same thing although I don't remember what it was, but the computer told him that A was wrong, he fixed B and boum, problem solved.
I'm not sure why, he isn't either. Just a weird car...
So check everything : and get the car to the dealership, they are used to it, and they might just reset the computer, and ask you to come back if it flashes again.
BMWChicago is offline   Reply With Quote
Old 12-15-2003, 03:20 PM   #7 (permalink)
350z
Car: 03 Nissan 350z Track
if your car is older with mileson it, the floater will start to grow stuff on it, and wont work properly i agree buy a new one and then problem should be fixed
David
**BAKER POW REPORT**
Tranny Fluid Level Check Beanster 3-Series (E36) 3 05-31-2005 09:12 PM
Coolant Level Warning 91525i 5-Series (E12,E28, E34, E39, E60) 2 08-06-2004 10:32 AM
VIN CHECK wax Bimmer Talk/Motorsports Talk 3 07-11-2004 05:34 PM
Coolant level cardio 3-Series (E36) 2 09-09-2003 10:09 PM
