CHECK COOLANT LEVEL msg - BMW Forum - BimmerWerkz.com
Old 04-01-2008, 01:20 PM   #1 (permalink)
000is is on a distinguished road
Unhappy CHECK COOLANT LEVEL msg
newbie here...hopefully someone can help with this problem i'm having.
lately my '94 325is has been flashing the CHECK COOLANT msg (sometimes) when i shut off the engine...doesn't seem like the coolant level is low though?
I check it when the engine is cooled down overnite and levels are full.
problem with the overflow tank possibly?
also get a beepbeepbeep sound sometimes when i'm driving but no msg on the led screen?
are these big problems???
thanx for the help!
forgedcbuser at gmail dot com
000is is offline   Reply With Quote
Old 04-01-2008, 01:25 PM   #2 (permalink)
I am Teh Edumacator.
Teh Prof's Avatar
The errant coolant warning could very well be the coolant level sensor, which goes bad sometimes.
The beeping noise might be your clock. There's a setting that causes beeping every hour on the hour.
Lindsay fan club member.
Old 04-01-2008, 01:32 PM   #3 (permalink)
i hope the fix is as simple as that...
it started a few weeks ago and pops in and out with the message.
stopped when i filled up the antifreeze almost to the top but came back a week later.
the beeping sound shouldn't be coming from the clock since i don't have any alarms or memos programmed (never have)...drives me nutz when it goes off!
Old 04-01-2008, 01:42 PM   #4 (permalink)
Teh Prof's Avatar
Might there be an aftermarket alarm system installed on your car from before you owned it? That was the case on my E36 M3, and it took me a while to figure out what was going on.
Old 04-01-2008, 01:48 PM   #5 (permalink)
don't think it's the alarm since i don't even use it...always off.
Old 04-01-2008, 02:13 PM   #6 (permalink)
Montizzle is a glorious beacon of lightMontizzle is a glorious beacon of lightMontizzle is a glorious beacon of lightMontizzle is a glorious beacon of lightMontizzle is a glorious beacon of light
Im 99% sure its just a faulty sensor. Its ar REALLY common thing. If your expansion tank is in ok shape, and your not leaking any coolant, you have nothing to worry about
99 Dakar M3
|Conforti|Sharked|TC Kline SA|DEPO||BBS|M50 MANIFOLD|UUC|DDM|SPARCO|OEM X BRACE||SSK|ECS TUNING|MISHIMOTO|
Montizzle is offline   Reply With Quote
Old 04-01-2008, 02:19 PM   #7 (permalink)
first off...NICE pic of your car.
yah, i check the underside and doesn't seem to be any leakage so (hopefully) just a bad sensor.
still better safe than sorry since i've read about head gaskets, etc cracking from the overheating.
thanx for the help!
Old 04-01-2008, 03:01 PM   #8 (permalink)
Mr. Bacon
dannyb's Avatar
Car: '08 Rabbit / E30 325is
dannyb is a glorious beacon of lightdannyb is a glorious beacon of lightdannyb is a glorious beacon of lightdannyb is a glorious beacon of lightdannyb is a glorious beacon of lightdannyb is a glorious beacon of light
Send a message via MSN to dannyb
the beep might be for the outside temperature, i have that also... i know its annoying but i live with it
Originally Posted by german-speed-demon View Post
that's my whore ; )
dannyb is offline   Reply With Quote
Old 04-01-2008, 03:23 PM   #9 (permalink)
Keep it Copacetic
///M Power's Avatar
Car: 1995 BMW M3
I bet you the beerp is related to the Memo function on your OBC (on board computer) which is that message system where it says low coolant. The Memo button looks like this roughly .))) press it to make that symbol disappear off your OBC screen next to the clock.
Sounds like a faulty coolant sensor.
Old 04-01-2008, 05:09 PM   #10 (permalink)
yup...the beep was from the memo being set inadvertently...thanx for that guys.
another thing i forgot to mention was that the passenger side floormat seemed to have some sort of fluid collected ([COLOR=blue ! important][COLOR=blue ! important]antifreeze[/COLOR][/COLOR] maybe?)...
and the other nite after it rained,
i opened the door to find that both mats had collected water?
sometimes when i get a car wash, water comes in thru the floor vents but never anything like this...?
Old 04-01-2008, 09:22 PM   #11 (permalink)
General Chaos
SpeedInfusion's Avatar
Car: ///M3,Corolla
water leaking in has to do with ur weather seals...
its the black rubber things around the inside of ur doors...when they go bad, water gets in...
its called the door seal on pelicanparts.com
Old 04-01-2008, 11:55 PM   #12 (permalink)
Im Bluffin With My Muffin
AlpineSixAndSeven's Avatar
Floor vents??
1992 318i Coupe parts car
I am Captain Obvious
Old 04-02-2008, 03:22 AM   #13 (permalink)
the water is actually coming thru the vents underneath the dash so i'm assuming the other 'fluid' must have come from there as well...
no H2O leaks from the door whatsoever.
Old 04-02-2008, 03:23 AM   #14 (permalink)
Originally Posted by AlpineSixAndSeven View Post
Floor vents??
meaning the vents just above your feet or under the dash.
Old 04-02-2008, 10:06 AM   #15 (permalink)
eurospec325i's Avatar
Car: 325i / 18" rims / euro rear lights
eurospec325i is on a distinguished road
Send a message via Yahoo to eurospec325i
no its not a big problem , when u look at the tank of antifreeze it looks full but still put some in that should help, if it still does the same theres a sensor in that same tank that has to be changed, the other beep u hear is nothing just a reminder , could temp , speed, or other, good luck , i had the same problem thats how i fixed it.
eurospec325i is offline   Reply With Quote
Check Coolant Level sre2114 3-Series (E36) 5 04-20-2005 02:19 PM
check coolant level message retomul 3-Series (E36) 4 07-24-2004 01:32 PM
coolant level check retomul 3-Series (E36) 0 07-24-2004 06:48 AM
how to check coolant level p3rsian 3-Series (E36) 6 05-16-2004 04:29 PM
Check Coolant Level greenhaus30 3-Series (E36) 5 01-10-2004 01:39 PM
