I just replaced the radiator on my (to me) 1998 323i. Before and particular since this, check-control tells me to the check the coolant level. I took it back to the mechanic and he indeed noticed the coolant level was too low and one of the clamps to the heater hose was not tight. Coolant was added and the clamp was tightened, but the light still goes on. Has anybody had similar problems? Is the computer “overly” sensitive (as my mechanic suggests) or do I have a con-tinued problem?? Ray
Yes, overtime many of the onboard sensors become overly so. The level can be easily checked. If you find it is at the right level, and your sensor persists, change the sensor.
I have a 6/92 325i that had the same problem. The coolant level was fine and the car didn't get hot (even in Phoenix in the summer). A new sensor fixed the problem.
Seems like a popular problem on all the message boards :banghead .
This is what happens when the factory seal leaks water to the reed relay inside the sensor body :wtf .
Note that the rad coolant does not cause this problem its from water and corrosion attacking from outside the bottom of the sensor where the large plastic nut is.
I just went through the same problem with my 92 e36 325i.
Change the sensor if jiggling the float in the overflow tank doesn't solve the problem.
Related Threads
BMW Werkz
668.8K posts
97.6K members
Since 2003
A forum community dedicated to all BMW owners and enthusiasts. Come join the discussion about performance, modifications, classifieds, troubleshooting, maintenance, and more for your favorite models!
