Check Coolant Level light .... - BMW Forum - BimmerWerkz.com
Old 09-06-2004, 03:04 PM   #1 (permalink)
lieshers
Guest
Posts: n/a
I recently purchased a '98 328i...and it's been awesome! But the "Check Coolant Level" light keeps coming up. It never runs HOT but the level is diminishing quicker than it probably should. I haven't noticed any leaks after sitting all night. There is not any white smoke coming out when I start it in the AM either.
Could this problem be serious?? Please help...
Thanks
Old 09-06-2004, 03:12 PM   #2 (permalink)
mstar is an unknown quantity at this point
see:
http://www.bmw-forums.com/forum/topic18317.html
i had the same problem as you. ghead
mstar is offline   Reply With Quote
Old 09-06-2004, 09:00 PM   #3 (permalink)
2.link's Avatar
2.link is an unknown quantity at this point
Send a message via AIM to 2.link
It won't really leak untill you are driving it. The radiator flows the water/coolant through the system by being pressurized while the car is running, meaning if there is a leak it will only leak while the radiator is cooling the coolant down. Drive it around a while and get it real warm, pull over open the hood and check for leaks. Or you can go pick up a tool that goes on where your cap is and pressurizes the system and then you can check for leaks.
<img src='http://www.european-forums.com/forums/uploads/post-1-1107198379.jpg' border='0' alt='user posted image' />
Formally known as Asio.
2.link is offline   Reply With Quote
Old 09-06-2004, 10:52 PM   #4 (permalink)
Car: 2008 128i
bleed the system and add coolant.
2008 128i Jetblack
Check Engine Light E36 325I 3-Series (E36) 15 07-21-2005 08:43 AM
Brake Light Check HoFF 3-Series (E21, E30) 2 07-13-2005 06:43 AM
Check Light Comes On For Brake Lights... HoFF 3-Series (E21, E30) 5 06-15-2005 07:12 PM
Inspection I iantosca 3-Series (E36) 5 09-18-2004 12:18 AM
check engine light and check light Scarface 3-Series (E36) 3 06-03-2003 08:31 AM
