Check Coolant Level - BMW Forum - BimmerWerkz.com
Old 04-19-2005, 04:01 PM   #1 (permalink)
sre2114 is an unknown quantity at this point
I have a 96 328is and whenever i turn the car off the check coolant level message flashes. We checked the coolant level and it is slightly above the cold line and none appears to be leaking. Could this be a sensor and if so how would i fix? And just out of curiousity where is the sensor located? Thanks for your help.
sre2114 is offline   Reply With Quote
Old 04-19-2005, 04:04 PM   #2 (permalink)
tomctx's Avatar
[snapback]334950[/snapback]
The sensor is on the expansion tank. This seems to be a common problem with our cars.
Old 04-19-2005, 07:10 PM   #3 (permalink)
Been here a while.
97alpineM3's Avatar
Car: Blah
OK... a few questions about your problem.. did you resently have your coolant changed...?
Are you checking the coolant level when the engine is cold.. or warm?
Just so you know.. you should fill her up a little above the cold... I've found that keeps that grip away pretty well...
Good Luck,
Les
1997 E36 M3 1990 E30 325i
Old 04-19-2005, 11:16 PM   #4 (permalink)
Threadkiller
bitcore's Avatar
Sensor. I have this problem too, i'm too lazy to flush and replace.
Old 04-20-2005, 12:11 PM   #5 (permalink)
PR325is is an unknown quantity at this point
Send a message via AIM to PR325is Send a message via Yahoo to PR325is
same thing happens to my car... when i shut off the car it tells me to check coolant level... need to replace coolant sensor!
PR325is is offline   Reply With Quote
Old 04-20-2005, 02:19 PM   #6 (permalink)
Thanks for the responses ill change the sensor when i decide to change the coolant. I do not know when the coolant was changed last but it hasnt been changed since dec 24/04 before that i dont know. We check it when it is cold and it is filled slightly above the cold line. Again thank you for your responces.
Inspection I iantosca 3-Series (E36) 5 09-18-2004 12:18 AM
check coolant level message retomul 3-Series (E36) 4 07-24-2004 01:32 PM
service questions thamindzzeye 3-Series (E36) 4 04-30-2003 02:40 PM
