Check control light - BMW Forum - BimmerWerkz.com
Old 08-25-2003, 09:55 PM   #1 (permalink)
Jajeta21 is an unknown quantity at this point
Alright, i need a little help, i got into my car after work tonight and when i turned on the car the check control light came on and it says brake light circut and then SEE OWNERS MANUAL. but the only problem is, is that i dont have a manual for the car yet. Anyonw know what this may be?? Thanks
<img src='http://www.bmw-forums.com/forum/uploads/post-4-1085796862.jpg' border='0' alt='user posted image' />
Jajeta21 is offline   Reply With Quote
Old 08-25-2003, 10:00 PM   #2 (permalink)
ex owner/admin
Furious's Avatar
do you have a brake light out? or all?
Old 08-25-2003, 10:04 PM   #3 (permalink)
no i dont, that was the first thing that i check cause thats what i thought it may be....any other ideas?
Old 08-25-2003, 10:06 PM   #4 (permalink)
ex owner/admin
Furious's Avatar
if its still there (the light) than all i can suggest is take it to the mechanic to see what it might be, also dont forget to check the middle brake light.
Old 08-25-2003, 10:16 PM   #5 (permalink)
all brake lights work...thanks though, always apreciate the help
Old 08-25-2003, 10:18 PM   #6 (permalink)
ex owner/admin
Furious's Avatar
wish i could help more but ive never had that problem
Old 08-25-2003, 10:49 PM   #7 (permalink)
Defector
El Presidente's Avatar
does the car have non-amber tails? If so, it is a common fault caused by swapping them.
Old 08-25-2003, 11:05 PM   #8 (permalink)
nope..everything is stock on it right now
Old 09-05-2003, 09:24 PM   #9 (permalink)
Brodieman is an unknown quantity at this point
I have read on some forum somewhere this might be due to contact problems,
try cleaning the brake light contact. Also I have read about burning on the contact.. apparently It's documented... sorry I cant remember the link to the exact page. (Apparently the OBC measures resistance of the circuit, and dirty can lead to a warning that a brake light has failed).
If it's not the contact try the below
Hope this links help
Brake Circuit Failure Fix
Good luck
Brodieman
Brodieman is offline   Reply With Quote
Old 09-05-2003, 09:44 PM   #10 (permalink)
cardio is an unknown quantity at this point
yea that warning comes up on my car every now and then, then it just goes away, i think u can take it to the BMW dealership and get somethin fixed for like 20 dollars and it will stop sayin that
cardio is offline   Reply With Quote
Old 09-06-2003, 08:35 AM   #11 (permalink)
the///man is an unknown quantity at this point
yeah it happend a while ago on mine and i looked for a burnt fuse but couldnt find one, the warning hasnt shown up since
the///man is offline   Reply With Quote
Old 10-20-2003, 09:36 PM   #12 (permalink)
Bryce is an unknown quantity at this point
Hey there, just saw your question on the Brake Light thingy.. This has happened to me and I have after talking to the BMW $tealers that there is a swtich that wears out of a period that needs replacing, around $70.00NZD this is the brake pedal switch which I was told was under the dash towards the passengers side. WHat happens is the switch sometimes makes and breaks contact and the check control see's that you have not touched the brake pedal and therefore knows something is wrong.. This is very common on 95-98 E36, my 99 E46 has just started doing this... Grrrr.
Cheers,
Bryce.
Bryce is offline   Reply With Quote
Old 10-21-2003, 01:45 PM   #13 (permalink)
DesmoBob's Avatar
the brake light switch at the brake pedal is the most common culprit. if you are willing to DIY, the actual part is only a few dollars.
details here:
http://www.geocities.com/karlkarlb/brakeswitch.html
Check Light Comes On For Brake Lights... HoFF 3-Series (E21, E30) 5 06-15-2005 07:12 PM
Can Fix My Air Pump Problem, Check Engine Light Esme 3-Series (E36) 1 05-05-2005 12:33 AM
Check Engine Light aheath 3-Series (E36) 1 04-27-2005 06:27 PM
Check Control Module? djianlaverick 3-Series (E36) 2 04-01-2005 09:30 AM
Traction Control Light nit78 3-Series (E46, E90) 2 01-28-2004 12:19 PM
