Check Brake Light Circuit? - BMW Forum - BimmerWerkz.com
Old 03-18-2005, 12:24 AM   #1 (permalink)
BMWfiend is an unknown quantity at this point
Just noticed my computer was flashing "Check Brake Light Circuit" tonight... but my brake lights work and everything? Don't really understand. If anyone could enlighten me that would be wonderful! Thanks
BMWfiend is offline   Reply With Quote
Old 03-18-2005, 07:14 AM   #2 (permalink)
tomctx's Avatar
[snapback]313903[/snapback]
Mine does that from time to time, and then goes away. I believe it's the brake light switch located at the brake pedal that needs to be replaced.
Old 03-18-2005, 07:17 AM   #3 (permalink)
yes, tomctx is correct. that message displays if the brake light switch is failing or failed. it is just under the dash near the brake pedal.
Old 03-18-2005, 12:36 PM   #4 (permalink)
Power Shifting
Cruzin 323is's Avatar
if u look hard enough.. there is a DIY somwhere on the forums.. and will give much more info on this problem!!
just can't find it right now!
goodluck
-SOLD..
R.I.P Fast 6
Old 03-18-2005, 02:22 PM   #5 (permalink)
RIBEMR26's Avatar
the DIY:
http://www.geocities.com/karlkarlb/brakeswitch.html
good luck getting under there if your any bigger than the average jockey...my neck just stopped hurting and I did it like 6 mos. ago...
Clear Corners and Sidemarkers
Old 03-18-2005, 02:32 PM   #6 (permalink)
Power Shifting
lol!
-SOLD..
R.I.P Fast 6
Old 03-18-2005, 11:04 PM   #7 (permalink)
theogill is an unknown quantity at this point
Send a message via MSN to theogill
Pelicanparts has a DIY on their site with pictures. I'm a pretty big guy and was able to do it, but it sure sucked. Be sure to get the right switch. If you have cruise control then you need the 4 prong one, if not, then just 2 prong. You'll have to break out the old one. Very easy to do technically, just a pain in the neck--literally.
98 328i, black/black, manual, canadian sport pkg, ECIS intake, koni sport adj's, dinan springs, oe/oem clears.
Considering: tms shark,M 17&quot; wheels, larger sway bars.
theogill is offline   Reply With Quote
Buying 1997 Bmw 318i - Need Your Help! newbmw 3-Series (E36) 7 09-06-2005 08:04 PM
Brake Light Circuit? jbnery6465 3-Series (E36) 11 02-17-2005 04:18 PM
Brake Light Circuit ebinkleybmw 5-Series (E12,E28, E34, E39, E60) 0 12-26-2004 02:51 PM
Inspection I iantosca 3-Series (E36) 5 09-18-2004 12:18 AM
HELP, e36 brake light curcuit fault code theogill 3-Series (E36) 4 08-27-2004 07:48 AM
