Hey,
I have got a 92 325is 5 speed and I noticed the valve cover gasket is leaking? Just looking for some info on how to replace this and if anyone has done it.
Hey,
Hi there, I too am actually in the middle of doing thsi exact job on my 325is, it's not all that bad doing it yourself. I picked up the valve cover gasket kit from a BMW dealership by me, cost about ohhh $120 cdn I beleive *receipt is at home while I'm at work right now* It's not all that hard, you just have to be careful, check out Pelican Parts and tech data to see how to take it off.
Though I have the bonus of my best friend is a mechanic, as is my father so i've also got all the tools
its a pretty simple replacement. i wrote up a bit on how to replace them on 6cly e36's a while back but pelican has a good indepth step by step with pics.
Hey, I looked over the pelican article, but I was wondering how much more is involved on my V8. Can I expect the same procedure or am I going to be in for a shock when I try to get the cover off, etc?
Should be fairly similar. Again, bentley service manual is the most valuable tool on the planet.
On my M50TU, it's retardedly easy to get the valve cover off and replace the gaskets. Pull all your ignition coils (mark them), remove bolts, clean off old gasket, replace with new, silicone... done. You guys have the same motor as my 525i, so... should just be a matter of getting to the bolts themselves. Real easy job, took me about 1.5 hours the first time I did it.
Related Threads
BMW Werkz
668.8K posts
97.6K members
Since 2003
