Changing Fog Light Bulb - BMW Forum - BimmerWerkz.com
Old 05-26-2005, 11:32 PM   #1 (permalink)
cymorg's Avatar
cymorg is an unknown quantity at this point
Send a message via ICQ to cymorg Send a message via AIM to cymorg Send a message via MSN to cymorg Send a message via Yahoo to cymorg
one of my fog lights is burnt out so i bought a new bulb and i cant figure out how to change them! i bought new bulbs and replaced both headlights with no problem and i figured the fog lights would be very similar to remove and replace but ... they seem to be different and i cant get the old bulb out (and therefore i cant get the new bulb in). the car is a 1995 or 1996 318i
whats the deal?
keep in mind i know very little about cars in general and even less about car maintenance. thanks for your help.
cymorg is offline   Reply With Quote
Old 05-26-2005, 11:48 PM   #2 (permalink)
Power Shifting
Cruzin 323is's Avatar
on the sides of the foglight.. there is a little space... sorta where the lower grill is... u have to, (with a screwdriver) pry out the foglights from its braket.. then its pretty much self explanitory..
-SOLD..
R.I.P Fast 6
Old 05-26-2005, 11:53 PM   #3 (permalink)
cymorg's Avatar
thanks very much
i was trying to pull the bulb out from the backside and it just wasnt working out
i'll give it a try in the morning
Old 05-30-2005, 01:58 AM   #4 (permalink)
cymorg's Avatar
so i got my light out and changed the bulb without a problem
still doesnt work. bulb wasnt even blown, apparently.
what could be the problem? the opposite fog light works fine
Old 05-30-2005, 05:10 AM   #5 (permalink)
///Matt's Avatar
You're not the first person who I've heard with this problem. Check the wiring from the bulb to the firewall. It may sound silly, but check the connections and make sure they are snug and not weathered to a point that they do not carry current. Most likely the wire has been damaged and needs mending. If there is no physical explanation then you may have a problem with your LCM (Lighting Control Module - I am not positive that the E36 is equipped with this). Occasionally this will create problems like one side is not powered.
Changing The Light Bulb In Headlight Switch ben_t 5-Series (E12,E28, E34, E39, E60) 2 06-09-2005 08:21 AM
OT: Group Buy - PIAA Light Bulbs alohalc 5-Series (E12,E28, E34, E39, E60) 0 07-21-2004 05:59 PM
Turn signal light bulb Blackdog 3-Series (E46, E90) 14 04-05-2004 12:22 PM
