Originally posted by jetblack@Jun 2 2005, 10:46 PM How do you know if your guibo needs replacement?? [snapback]349717[/snapback] |
Well, first off, this is my first ever bimmer!!! love it!
I found out cause I am a AAA member. after I bought my bimmer, I took it to a AAA fascility and they do a diagnostic check on all systems of your car to see if there is anything that needs to be replaced. sure enought he tells me the flex disc "guibo" on my drive shaft is cracking. so I get under the car, look at it and it's cracking, so I figure I should replace it before I actually HAVE symptoms, cause don't want to mess with a janked up drive shaft while on the highway!
so, you dont pull any spline shaft out of the back of the tranny in the process?
