Change Oil - BMW Forum - BimmerWerkz.com
post #1 of 16 (permalink) Old 08-23-2005, 09:26 PM Thread Starter
spotteddog is an unknown quantity at this point
I have a '97 328ic, fairly new to me. So.... here's my dumb question, how do I DIY change oil? Location of filter---is it on top near the radiator? If so, what special tool or socket is needed to fit it? Oil drain plug...what size wrench is needed? Thanks for your help! Also, any recommendations for oil type, this has 76K miles, driven in Ohio.
spotteddog is offline
post #2 of 16 (permalink) Old 08-23-2005, 09:29 PM
WarNox's Avatar
oil filter is on top, got no idea about the wrenches! there is a DIY on this somewhere but i cnt remember, mite have read it in a haynes (wasnt too bad actually), my car needs 6.5L of oil nd 10W40 but not that this helps you, well good luck!
<img src='
WarNox is offline
post #3 of 16 (permalink) Old 08-24-2005, 12:39 AM
SD318is is an unknown quantity at this point
if you dont have an assortment of wrenches just use a cresent wrench. get the oil filter from a dealership cause it comes with the new o-rings and washers
SD318is is offline
post #4 of 16 (permalink) Old 08-24-2005, 01:54 PM
Shudogg's Avatar
Shudogg is an unknown quantity at this point
here.....
http://www.pelicanparts.com/bmw/techarticl...-Oil-Change.htm
<span style='color:red'>
CLASSIFIED</span>
<span style='color:blue'><a href='
target='_blank'>WHIPLASHDVD.COM</a></span>
Shudogg is offline
post #5 of 16 (permalink) Old 08-24-2005, 01:56 PM
Here's the Pelican Tech article on oil changes.
E36 Oil Change
Drain the oil from the pan first before removing the filter or you'll have a huge mess. Call around and see if any of the auto parts stores in your area have the filter, sometimes NAPA does. It'll have the new big O-ring for the filter housing and a new drain plug seal ring. I recommend Mobil One synthetic oil, in whatever viscosity suites your operating environment. Check your owner's manual.
Mike
Hamfisted is offline
post #6 of 16 (permalink) Old 08-24-2005, 02:18 PM
Shudogg's Avatar
thanks man...hah
CLASSIFIED</span>
Shudogg is offline
post #7 of 16 (permalink) Old 08-24-2005, 04:04 PM
drz
Administrator
drz's Avatar
Quoted: 1 Post(s)
drz has a reputation beyond repute drz has a reputation beyond repute drz has a reputation beyond repute drz has a reputation beyond repute drz has a reputation beyond repute drz has a reputation beyond repute drz has a reputation beyond repute drz has a reputation beyond repute drz has a reputation beyond repute drz has a reputation beyond repute drz has a reputation beyond repute
I buy MANN filters from bavauto.com. They come with the new O-ring and cost only $8. A FRAMM filter in Autozonne cost me $15
drz is offline
post #8 of 16 (permalink) Old 08-24-2005, 08:49 PM
got a oem filter from the dealer for $9
SD318is is offline
post #9 of 16 (permalink) Old 08-25-2005, 09:34 AM
drz
Administrator
drz's Avatar
Quoted: 1 Post(s)
^^ I'll check with the dealership in my area. If they are only $9, I'll stop paying for shipping.
drz is offline
post #10 of 16 (permalink) Old 08-25-2005, 10:48 AM
pcy
pcy is an unknown quantity at this point
[snapback]372302[/snapback]
Most of the on-line parts sellers don't charge for shipping if your order is over $50. So, I usually buy several filters together (for both 328i and ML320).
BMW oil filter is around $7 on-line.
On the other hand, if you need a filter right-a-way, your local dealer may not be bad (around $9).
pcy is offline
post #11 of 16 (permalink) Old 08-25-2005, 06:18 PM
drz
Administrator
drz's Avatar
Quoted: 1 Post(s)
Originally posted by pcy+Aug 25 2005, 09:48 AM--><div class='quotetop'>QUOTE(pcy @ Aug 25 2005, 09:48 AM)</div><div class='quotemain'><!--QuoteBegin-drz328i@Aug 25 2005, 08:34 AM
[snapback]372314[/snapback]
[/b][/quote]
Yeah -- I know. I usually get a filter or a few whenever I get anything else for my car. I have several purchases coming in the near future, so I may stock up then. I am completely out right now.
drz is offline
post #12 of 16 (permalink) Old 08-25-2005, 11:09 PM
Devil Man is an unknown quantity at this point
i belive that the wrech for the oil filter is a 30 mm i could be wrong though i cant remeber off the top of my head. and the oil plug is a 17mm i belive. i would use a socket for the drain plug. as for oil it doesnt matter if you go regular just change the oil around 3000-3500 miles, with synthiatic you can go to about 7000miles, though the catch behind that is that you are suposed to change the filter in the middle of that, nobody does, and not to many people know that, but thats what mobil 1 says. i would go ams oil if you want synthiatic.(spell?) good luck!
Devil Man is offline
post #13 of 16 (permalink) Old 08-26-2005, 12:17 PM
drz
Administrator
drz's Avatar
Quoted: 1 Post(s)
Oil filter cap: 36mm.
drz is offline
post #14 of 16 (permalink) Old 08-26-2005, 04:02 PM
pcy
It's difficult to locate a store that sells 36mm socket.
Try "Farm and Fleet" store, if there is one around where you live.
I bought one there for $5.
pcy is offline
post #15 of 16 (permalink) Old 08-26-2005, 04:33 PM
drz
Administrator
drz's Avatar
Quoted: 1 Post(s)
I walked right into Sears and got it there. You should be able to get it online also. I am certain you don't need to use a socket -- ther are ways around this --, but I'd rather do things the right way.
Also, there is a tool that bavauto sells (no, I don't work for them) that on one end is a 32mm wrench (necessary to remove fan) and a 36mm on the pther end. This wrench is not very think, so making it fit betweeen the radiator and the fan is easier than using a regular wrench. Just in case you are in the market for something like that.
drz is offline
Oil pan replacement Q's jk988 3-Series (E21, E30) 15 05-02-2007 07:56 PM
E32 transmission oil bimmertuner07 1,6,7,8 - Series and Mini Cooper 3 03-15-2006 12:03 PM
what transmission and differential oil should i use? träumer 3-Series (E21, E30) 6 10-10-2005 02:42 PM
A Year Passed And I'm Still Not Changing The Oil AIO 3-Series (E46, E90) 26 10-10-2005 09:43 AM
timing belt change and mechanics in miami träumer 3-Series (E21, E30) 6 10-03-2005 04:44 PM
