Chain, Tensioner Change - BMW Forum - BimmerWerkz.com
Old 06-21-2005, 09:25 AM   #1 (permalink)
DiRay's Avatar
DiRay is an unknown quantity at this point
NEED URGENT HELP, Need manual to change chain on my 325i 1992-10
I hawe a picture what I'm planing to change also the chain too.
[attachmentid=22508]
DiRay is offline   Reply With Quote
Old 06-21-2005, 10:39 AM   #2 (permalink)
fredo328's Avatar
fredo328 is an unknown quantity at this point
Send a message via Yahoo to fredo328
This might give you some info you can use:
http://www.pelicanparts.com/BMW/techarticl...haft-Timing.htm
<img src='http://home.comcast.net/~farrieta/index_files/image001.jpg' border='0' alt='user posted image' />
<a href='http://www.328i.org/index.php' target='_blank'>328 life</a>
1998 328
fredo328 is offline   Reply With Quote
Old 06-23-2005, 03:56 AM   #3 (permalink)
DiRay's Avatar
Need this to remove rustling noise.
Work is in progres, let you guys know when finished.
Las week I went to dealer an thei told me that almost all E36 has this problem,
Thei told me that you need to update your VANOS,
All E36 manufacturing period 03.1990 to 06.1995 need this update.
[attachmentid=22534][attachmentid=22535]
Old 06-23-2005, 12:44 PM   #4 (permalink)
This was a common fault you need special tool to lock the cams, pre tension the chain, lock the flywheel etc and a good set of torque sockets
Old 07-01-2005, 07:32 AM   #5 (permalink)
DiRay's Avatar
B) Finally that rustling noise is gone
Also had changed 2 of 3 chains thermostat and plastic .| tube near thermostat.
Now my baby runs like a bee no more unnecessary sounds.
timing chain tensioner? eclipsevrl 3-Series (E36) 4 01-05-2006 05:33 PM
Timing Chain Tensioner Swap, Is It Possible? victorgallas 3-Series (E36) 0 03-29-2005 02:25 PM
Timing Chain Tensioner. victorgallas 3-Series (E36) 0 01-19-2005 03:46 PM
Ta Ta Ta Ta...timming Chain Tensioner BMW Lover 3-Series (E21, E30) 5 11-09-2004 10:08 PM
Should Change The Timing Chain Now? shuiyuan 3-Series (E36) 7 10-24-2004 05:11 PM
