Ceramic Brake Pads?? - BMW Forum - BimmerWerkz.com
Old 04-04-2005, 05:53 PM   #1 (permalink)
mmclaren is an unknown quantity at this point
Just need a new set of brake pads for my car. I saw ceramic but i remember reading something about they sucked? can anyone confirm this
mmclaren is offline   Reply With Quote
Old 04-04-2005, 07:08 PM   #2 (permalink)
Threadkiller
bitcore's Avatar
Depends, really.
I dont really know but I'm rather happy with an all around set of hawk HPS. They squeal like a bitch so get some paste!
Other good ones: EBC green stuff, hawk HPS, the AXXIS pads on bavauto.com, MetalMasters
Use the search feature
Old 04-04-2005, 09:31 PM   #3 (permalink)
Power Shifting
Cruzin 323is's Avatar
the thing with ceramic pads... is, inorder for best usuage, the pads need to be hot..
PBR pads IMO are the best!
-SOLD..
R.I.P Fast 6
Old 04-05-2005, 03:38 AM   #4 (permalink)
axxis is an australian company i can get those brake pads hell cheap $30 a set in au or 24 us which i think is cheap lol
Old 04-05-2005, 06:21 PM   #5 (permalink)
abemcclellan's Avatar
abemcclellan is an unknown quantity at this point
i replaced mine with Mintex pads all around. and they haven't even squeaked yet. and its been over half a year.
abemcclellan is offline   Reply With Quote
Old 04-05-2005, 06:29 PM   #6 (permalink)
Been here a while.
97alpineM3's Avatar
Car: Blah
I would match a good set up ceramic pads with a really really new and high temp rated rotors... if you dont have that... you also have to look at the use of ceramic.. yea.. they are the best.. but only under certain conditions... as stated in one of the past posts....
Get normal street... or street/racing pads... ceramic pads are wayyy to much for a street car.. unless you are going to drive more on a track... than on the street...
Good Luck,
Les
1997 E36 M3 1990 E30 325i
Old 04-05-2005, 07:22 PM   #7 (permalink)
CiscoKid's Avatar
they take awhile to warm up... and you need to match them with special rotors... i would just go OEM/Sport pads
Old 04-06-2005, 09:29 AM   #8 (permalink)
Car: 1993 325i
victorgallas is an unknown quantity at this point
Send a message via ICQ to victorgallas Send a message via AIM to victorgallas Send a message via MSN to victorgallas
[snapback]325523[/snapback]
If this is a street driven car, do not fall for the ceramic, reason is that ceramic must be hot to work efficiently, they make a lot of noise until warm. Also and this is the big problem that shows up later. IF you use ceramic pads on regular rotors, youll simply eat ure rotors away and warp them from heat, that is the first issue, then comes the others, the extra heat will, im not kidding here, damage your seals on the caliper, the seals are made of rubber and other materials and they are designed to withstand up to a certain working temperature, therefore youll damage the seals, and the calipers itself, since damage seals makes calipers to become frozen,. they dont retract.
And lastly, the extra heat generated will easily decrease your bearing life, since you will put heat on it and slowly, damage its internal grease , therefore the bearing.
Ceramic pads are for racing, reason being, they need to be hot, and when they are in use, everything around them must be made to work with them.. keep that in mind, so you dont have future problems.
You are a BMW driver when you become part of the "Ultimate Driving Machine"
Fraude an Fahren
BMW > Bayerische Motorenwerke
Auf Viedersehen der herr
www.clemsonfsae.com
victorgallas is offline   Reply With Quote
Old 04-06-2005, 10:20 AM   #9 (permalink)
NeverLeaned is an unknown quantity at this point
Send a message via AIM to NeverLeaned
Cermaics aren't really for street. If you do auto-crossing/racing then by all means upgrade and deal with mushy breaks while they get up to temp on the street.
Otherwise, there are plently of great upgrade pads for your car. Consider PBR(axxis) Deluxes or Ultimates.
I noticed nice improvements with the Deluxes & Zimmerman X drilled rotors.
You really should consider pads that are suited to your driving needs.... Where-as cermanics are excellent if you like to stomp on brake late in a corner @100mph, you'll probaby find that they are no better then stock in most situtations (because they just don't get hot enough running on the street)
1996- BMW 328IS
<img src='http://img.photobucket.com/albums/v242/gws226/TEX/neverleanedsig.jpg' border='0' alt='user posted image' />
Performance: Zimmerman Cross Drilled Rotors-- PBR Deluxes-- Cosmos CAI---- Turner Pulley Kit--- Fan Delete mod---
Beauty: 18 polished M-Parallel replicas, Inpro Euros w/ Enchanced Angel eye kit, 20% tint
Clear corners/sidemarkers ---- Eurospec (Depos)
To do list:
Suspension--- researching
UUC System U TDM- 3/05
M50 manifold converstion 3/05
NeverLeaned is offline   Reply With Quote
Old 04-06-2005, 01:31 PM   #10 (permalink)
Car: 1993 325i
[snapback]326590[/snapback]
Again i support what he says,
i have Brembo cross drilled and pagid regular brake pads, honestly, best deal.,
The regular pads are quieter, work great for street use. They may not last long, but then again brake pads are a joke to replace, so its not a big deal..
O yeah and its been 2 years since ive replaced them..
You are a BMW driver when you become part of the &quot;Ultimate Driving Machine&quot;
Fraude an Fahren
BMW &gt; Bayerische Motorenwerke
www.clemsonfsae.com
Old 04-06-2005, 07:26 PM   #11 (permalink)
DesmoBob's Avatar
ultimates are ceramic.
(ceramic & kevlar)
Old 04-06-2005, 07:32 PM   #12 (permalink)
Typo.... that was supposed to be metal-masters..
thanks for correcting
1996- BMW 328IS
To do list:
Old 04-06-2005, 07:44 PM   #13 (permalink)
this is a cool FAQ resource to lay out the pro's and cons of each pad type....... (albiet they no longer have the ultimates in the list though)
http://www.axxisbrakes.com/technical.htm
1996- BMW 328IS
To do list:
Ceramic Brake Pads Aydin 3-Series (E46, E90) 1 09-13-2005 09:16 PM
Brake Pads ///M Power 5-Series (E12,E28, E34, E39, E60) 20 08-12-2005 09:26 PM
Aftermarket Brake Pads. HardStep Product Reviews 2 01-11-2005 11:44 AM
Need New Brake Pads And Rotors And Have Some ?'s elbee 3-Series (E46, E90) 4 12-18-2004 05:25 PM
ceramic brake pads?? chungaa1 3-Series (E36) 3 08-30-2004 07:54 PM
