Care to enlighten me? - BMW Forum - BimmerWerkz.com
Old 07-08-2004, 12:11 AM   #1 (permalink)
WOT in Reverse
jllphan's Avatar
is this?
Old 07-08-2004, 12:27 AM   #2 (permalink)
If you open your hood its on the front right side, I think its a sensor to know if the hood is closed or not.
Old 07-08-2004, 08:47 AM   #3 (permalink)
Car: 2008 128i
yes but what does it do...
i can start the car with hood open.
I think i can move the car with the hood open. (haven't needed to so haven't tired.)
2008 128i Jetblack
Old 07-08-2004, 09:46 AM   #4 (permalink)
Defector
El Presidente's Avatar
if you look in the fuse box, there is a fuse for a light in the engine. i have never found this light, but there is a fuse for it, and I have always assumed that is the switch.
Old 07-08-2004, 09:53 AM   #5 (permalink)
Car: 2008 128i
I see the punch out for the light in the hood. but no light.
2008 128i Jetblack
Old 07-08-2004, 10:13 AM   #6 (permalink)
BlantonG13's Avatar
BlantonG13 is an unknown quantity at this point
Send a message via AIM to BlantonG13
Just because the sensor isn't pressed for the hood being up, doesn't mean the car doesn't have to start does it? Unless its part of the security system, then it would make sense...It does makes a cool little click noise when you press on it...I'm easily amused...
1996 318i
5 Speed Manual
Alpine CDA-7895 Head Unit
12&quot; Alpine Type-R, sealed box
Infinity Kappa 4&quot; 2-way speakers(rear)
Infinity Kappa 5.25&quot; component speakers(front)
Debaffled airbox, K&amp;N filter
Tracked Mud on carpets
Shampooed and cleaned carpets
BlantonG13 is offline   Reply With Quote
Old 07-08-2004, 10:22 AM   #7 (permalink)
WOT in Reverse
jllphan's Avatar
Live the Curves, you are the lucky winner, any thing off the top shelf. :P
I was at my mechanic's shop to reset my oil change light, and asked him about it. He said that is indeed what it is. It works in conjunction with the oem alarm. IF you have keyless entry, when engaged, it will beep three times. Each beep is a respective sensor mounted throughout the car. This being one of them.
On a side note, he said they actually install one of these behind the oem radio in the convertible models for obvious reasons, pretty cool.
Old 07-08-2004, 01:08 PM   #8 (permalink)
Defector
so more importantly...
what about my hood light?
We have a fuse
we have a spot for the light
Why no light?
Old 07-08-2004, 01:12 PM   #9 (permalink)
I have that too, but the wires are cut for some reason.. snip snip
Old 07-08-2004, 01:26 PM   #10 (permalink)
Car: 2008 128i
the punch out looks like it will fit a trunk light....
I shoud look for the wires if they are there maybe i will get a hood light..
2008 128i Jetblack
Old 07-08-2004, 01:50 PM   #11 (permalink)
BlantonG13's Avatar
ohhh, thats what all the beeping is for...makes a lot of sense now. I always wondered. I thought it was the equivalent to the horn blowing for a quick sec. when other cars engage alarms.
1996 318i
5 Speed Manual
Old 07-08-2004, 10:26 PM   #12 (permalink)
325isBaby's Avatar
Car: 2005 330xi
This is an imput to the GM to let the car know if the hood is open, closed, or in "service mode". If it alwasy reads open, the car will still run and work properly, but the modules in the car will never go to sleep which equals high conumer and eventually dead battery. It can be tied in to DWA for alarm if the hood is tampered with. Hopefully this is found to be helpful.
And I also have the stamp out for the light but no light in the spot...don't know if this is a typical item to disappear or what.
Come see me at MySpace
Old 07-08-2004, 11:04 PM   #13 (permalink)
Car: 2008 128i
which modules would sleep?
2008 128i Jetblack
Old 07-08-2004, 11:06 PM   #14 (permalink)
325isBaby's Avatar
Car: 2005 330xi
Almost all modules go into sleep mode after 16 min (approx) just to limit current draw so you don't end up with a drained battery.
Old 07-09-2004, 01:29 AM   #15 (permalink)
WOT in Reverse
jllphan's Avatar
Curious. It's been laying inside my hood and has not "slept" since I bought the car. I haven't had any battery issues, and I certainly tax it with the aftermarket audio installed throughout the car.
Convertible Top Care Davecpa 3-Series (E46, E90) 2 05-21-2005 01:57 AM
How to take good care of Leatherette? chirayus 3-Series (E46, E90) 3 08-07-2004 10:20 AM
Take care the Alcantara/cloth upholstery ming04 Wash & Detail 3 06-04-2004 04:43 PM
Care for leather seats in my M3 Cndrella's M3 Wash & Detail 8 04-02-2004 11:51 AM
LEATHER CARE.. Ski Wash & Detail 2 05-24-2003 08:58 AM
