Car Wont Start When Cold - BMW Forum - BimmerWerkz.com
Old 03-02-2005, 06:31 AM   #1 (permalink)
mcmanamon is an unknown quantity at this point
Hi guys – I would apreciate if anyone could help – I have 325i E36 convertible 6 cyclinder. And the car will not start when its cold ONLY. I have taken it to a garage they were very help full – there is absolutely no errors on the computer – so its running like a dream – however when its cold (about 1degree C) then the bitch won’t start – the guys at the helpful garage have no idea – but one of their mates at BMW said it’s a faulty block – common problem that BMW will repair free of charge – the only problem is convincing BMW will be the difficult part – he said – so I hopped on this forum to find some evidence but I can’t find any. Does anyone heard of the same problem and if they have had the engine replaced what was the best way of approaching BMW – lets admit it they are slimy bastards.
PS love the guys posting pictures of there nude girlfriends – keep up the good work
regards
mcmanamon is offline   Reply With Quote
Old 03-02-2005, 10:10 AM   #2 (permalink)
Agent2828 is an unknown quantity at this point
Send a message via AIM to Agent2828
Your battery probably needs to be changed. For each degree drop, there is a significant decrease in the amount of power a battery can put out. If the battery is weak, the car won't start.
You can test if the battery is the problem by trying to jump start your car.
Agent2828 is offline   Reply With Quote
Old 03-02-2005, 10:11 AM   #3 (permalink)
CiscoKid's Avatar
batteries usually die in the cold.
doess it turn over, or does it do nothing
Old 03-02-2005, 10:14 AM   #4 (permalink)
Thanks for your reply - the battery will turn her over for hours - anything other suggestions - when the recovery guy turned up and he connected his leads we still had the same problem
[snapback]302451[/snapback]
Old 03-02-2005, 10:16 AM   #5 (permalink)
I tried to jump start it but it would work - I'll try again
Old 03-02-2005, 11:09 AM   #6 (permalink)
rsn48 is an unknown quantity at this point
I have been thinking about your car and it has to be software or plug problem. The old formula of suck, push, bang, blow hasn't changed. So if gas and air is making it into the cylinder and it is receiving an electrical current, it has to work. LOL... in Canada one degree Celsius is a warm winter day, not cold. If "cold" were an issue, then all those cars in Canada would be having troubles big time.
I'm putting my money on a software or sensor glitch.
rsn48 is offline   Reply With Quote
Old 02-09-2010, 12:51 PM   #7 (permalink)
Car: 1995 525i
denben is on a distinguished road
By the way, we are not all GUYS, some of us are Gals who have husbands who know nothing at all about cars so we have to fix our own cars. And it's THEIR nude girlfriends, not THERE
denben is offline   Reply With Quote
Old 02-09-2010, 01:51 PM   #8 (permalink)
92cleanbeam is on a distinguished road
It is possible to have a battery that operates fine under normal temps but its the cranking amps you need to check on the battery. I was having the same problem when it got to 10*F. Except my battery was fine it was the battery terminal that was just loose enough. I wiggled it, tightened it and BAM! it worked. Anyways what I am saying is I have had batteries work just fine once the temp was in mid range but go bad when it got cold out. You can take the battery to a shop to have it load tested. Which will tell if it has enough cranking amps. It may still have 12volts but not enough cranking amps. Good Luck!
92cleanbeam is offline   Reply With Quote
Old 02-09-2010, 01:54 PM   #9 (permalink)
BTW tell your mechanic that your car isnt a DIESEL! Its not like it needs a block heater or anything.
Old 02-09-2010, 11:10 PM   #10 (permalink)
seppy is on a distinguished road
crank sensor or air flow meter.
seppy is offline   Reply With Quote
Old 02-15-2010, 02:33 AM   #11 (permalink)
darkhorse737's Avatar
Car: 88 super ETA, 95 525i
Lightbulb
ENGINE TEMP SENSOR!
you have a heat gun... blow some hot air onto that guy(but not too hot or u will melt the insulation) and start ur engine. if it starts, there's ur answer ;-)
Old 02-16-2010, 03:29 AM   #12 (permalink)
p-fletch is on a distinguished road
Try replacing air filter and air flow regulator
p-fletch is offline   Reply With Quote
Old 02-16-2010, 10:41 AM   #13 (permalink)
zackpc2010 is on a distinguished road
It looks like your battery is dead
HID Lights Info
zackpc2010 is offline   Reply With Quote
Old 02-16-2010, 12:55 PM   #14 (permalink)
holly dog meat batman! Just replace every part on the car and theres your answer.
Old 02-16-2010, 08:05 PM   #15 (permalink)
CanadianWraith's Avatar
Car: 1996 318is
CanadianWraith is on a distinguished road
I tip my hat to thee fair lady!
CanadianWraith is offline   Reply With Quote
Cold Start valve... 97alpineM3 3-Series (E21, E30) 9 10-14-2005 02:58 PM
problems starting car when cold... VLAD_325is 3-Series (E36) 8 09-12-2005 08:08 PM
Growl/Gurgle Noise at Cold Start... HELP mathetas 3-Series (E36) 16 08-17-2004 09:12 AM
Cold Start Problem (fuel Pressure Drop) BEX 3-Series (E36) 6 05-16-2004 07:35 PM
1989 325ix cold start problems All wheels rolling 3-Series (E21, E30) 0 10-19-2003 06:29 PM
