| All gasoline combustion engines need four things in order to run: Air, Fuel, Spark, Compresion. Usually in that order. Let's find out which one your missing.
Spark is obviously an issue if their getting damaged. Are they the correct gap?
The ICV or Idle Control Valve is what allows the car to idle and when it gets clogged or fails the car won't idle without constant fuel. Also check your vacuum lines to make sure their are no cracks or tears. Vacuum leaks can cause starting and idling issues.
__________________ ProjectTechnik.com - Alberta based BMW Community See My car on Project Technik HERE! Click HERE to see my E36 Blog | OE M3 Bumper | M3 Mirrors | Jim Conforti CF CAI | UUC Motorwerks Underdrive Pulleys | 18x8 ASA AR1's | Koni Sport Springs & Shocks | |
