| I'd guess its the fuel pump as well. If you want to check it 100%, have a look at the relay that supplies 12volts to the fuel pump, make sure the relay is good, then if you want to take it 1 step further, supply 12 volts directly to the relay pin that goes to the fuel pump. If after applying 12 volts there is no noise from the pump, you have pretty much assured yourself of identifying the fault.
__________________ Riding in style |
