Car Won't Start Starter Relay Suspected - BMW Forum - BimmerWerkz.com
Old 06-15-2005, 09:14 PM   #1 (permalink)
BImmerN2B's Avatar
BImmerN2B is an unknown quantity at this point
Heyy guys, I have a big problem with starting my car. The problem that I try to start my car and all I hear is one click from the starter. I know that most of you will say that is the starter, but that ain't it because it has already been changed and both of them (old and new) were working fine. The battery is not either because I just bought an Optima battery about 2 weeks ago. This problem has happened to me before but the car (seems to have a mind of its own) has started again like nothing happened. then it works fine for a while and then it happens again(doesn't want to start). This time the car seemd not to like me and for 2 weeks straight it doesn't want to start.
I tried to change the Starter Relay which I suspect to be the culprit but could not find it. It's supposed to be on the left hand side of the dash but is not there. I found a similar one but is the Crash-alarm relay. Can anyone help locate the starter relay or help me think as to what the problem could be?.
BImmerN2B is offline   Reply With Quote
Old 06-16-2005, 10:36 PM   #2 (permalink)
BImmerN2B's Avatar
free bump
Old 06-17-2005, 09:11 AM   #3 (permalink)
pcy
pcy is an unknown quantity at this point
Originally posted by BImmerN2B@Jun 16 2005, 10:36 PM
free bump
[snapback]354316[/snapback]
In the past, I've read posting similar to yours, the person finally ended up fixing it by replacing either the Camshaft sensor or the Crankshaft sensor. Sorry, I can't be specific which one of those 2 sensors. The symptoms were car will start flawlessly some times and then sometimes it just doesn't.
good luck
pcy is offline   Reply With Quote
Old 06-23-2005, 05:31 PM   #4 (permalink)
jkh2828 is an unknown quantity at this point
sorry this is late - but if you are still having trouble - there is a "neutral safety switch" that could be problematic. Did you try starting the car in N instead of P (obviously this only applies if you have an auto)
<img src='http://www.jbheiss.com/pics/BMW.jpg' border='0' alt='user posted image' />
jkh2828 is offline   Reply With Quote
Old 06-23-2005, 08:40 PM   #5 (permalink)
BImmerN2B's Avatar
THank you all for your replies, what happened with my car was there were some cables loose on the starter. My car is a 5 speed so the neutral safety switch was not the issue and neither was the relay. I feel like a jackass for not looking there first. I thank you all for your help and from the looks of it, it won't be the last time either.
Old 06-24-2005, 06:36 AM   #6 (permalink)
The starter relay is only fitted to cars with auto gearboxes
Help E39 Won't Start SKT174 5-Series (E12,E28, E34, E39, E60) 12 07-25-2009 10:03 AM
Car Won't Start - Help - Fuel Pump Relay? e36is 3-Series (E36) 24 09-08-2005 05:51 PM
'93 325i Won't Start 86VFR750R 3-Series (E36) 3 12-05-2004 08:32 AM
Why Won't She Start? nicolecass81 3-Series (E36) 4 11-09-2004 05:38 PM
325I won't start in heavy SUNLIGHT 325iconverted 3-Series (E21, E30) 3 07-09-2004 12:15 AM
