Car won't start again! - BMW Forum - BimmerWerkz.com
Old 02-24-2004, 11:46 PM   #1 (permalink)
What? No Autobahn?
jrhaile's Avatar
Car: 2001 M5
jrhaile jrhaile jrhaile jrhaile jrhaile jrhaile jrhaile jrhaile jrhaile jrhaile jrhaile
Send a message via ICQ to jrhaile Send a message via AIM to jrhaile Send a message via MSN to jrhaile
Yeah okay so a month ago, car wouldn't start... ended up being that my sparkplugs/wires were covered in oil and some other shit... so at that time I replaced, cleaned up and fixed a minor oil leak... car has been awesome until this morning...Had my car on and warming up this morning and then I turned it off and went back inside for maybe 20 seconds... came back out and nothing.. car will turn over and it gets to the point where it sounds like it's going to start but doesn... so I let it sit all day until about 2 hours ago and tried it again thinking maybe it's flooded or something because that's what it sounds like when it's trying to start...still nothing, same sound from engine... so I checked the fuel pump and it works fine... I took off the manifold and checked the wires and plugs and those are fine and have no oil or anything preventing them from getting a spark... so now that's where my talent on working on cars runs out... I'm lost! What can I check! Also I should mention, when I had my plugs and wires fixed a month ago, I also had my mass air flow sensor replaced...
Any ideas? This is a 95 325i
jrhaile is offline   Reply With Quote
Old 02-25-2004, 10:30 AM   #2 (permalink)
ex owner/admin
Furious's Avatar
hmm, so you are getting spark? have your tried to test for spark?
Old 02-25-2004, 08:34 PM   #3 (permalink)
What? No Autobahn?
jrhaile's Avatar
Car: 2001 M5
I haven't checked for with the plugs and wires being less then a month old they couldn't have gone bad again could they?
Old 02-25-2004, 08:48 PM   #4 (permalink)
zizux's Avatar
zizux is an unknown quantity at this point
My gf's car won't start either, It had an injector take a crap. Or so the local dealer told me.
So I replace the injector, and pulled it into the garage, then she started it later the next day. It ran for a little while then shut off while she was letting it warm up. I messed with it for a while. But I can't figure it out, fuel is showing up, and it sounds like its sparking, WTF could it be?
zizux is offline   Reply With Quote
Old 02-25-2004, 09:15 PM   #5 (permalink)
What? No Autobahn?
jrhaile's Avatar
Car: 2001 M5
I don't know but I'm lost... every month I've had an issue ever since it got cold lol... I got this car in july and it worked great up until about late december and then I started having issues....
hey what does the mass air flow sensor do? could this cause my car not to start if it's not working correctly?
Old 02-25-2004, 10:03 PM   #6 (permalink)
ex owner/admin
Furious's Avatar
could be your O2 sensor, have you scaned for codes?
Old 02-26-2004, 12:34 AM   #7 (permalink)
What? No Autobahn?
jrhaile's Avatar
Car: 2001 M5
okay the noobie by my name doesn't lie.. I'm a noobie! how do I scan for codes? thanks for responding btw...
Old 02-26-2004, 12:38 AM   #8 (permalink)
Defector
El Presidente's Avatar
the MAF measures the amount and density of air coming into the engine the DME adjusts the fuel flow accordingly.
Also, this link details how to retrieve your faults and tells you what each means. http://www.europeantransmissions.com/Bulle....BMW/bmwcod.pdf
Old 02-26-2004, 01:33 AM   #9 (permalink)
What? No Autobahn?
jrhaile's Avatar
Car: 2001 M5
that says for 89-94, mine is a 95 will this still work?
Old 02-26-2004, 10:31 PM   #10 (permalink)
TECH's Avatar
Wires?
How do you know the fuel pump is working fine?
Old 02-26-2004, 10:34 PM   #11 (permalink)
TECH's Avatar
Sometimes those engine do flood, and I believe that it might be the idle valve sticiking closed, which would starve the engine of air at idle, and it would flood........that's a theory anyway.
Pull the fuel pump fuse, floor the gas pedal, and crank it over for a few seconds.
Put the fuel pump fuse back in and see if it'll start.
If not, floor it until it does......if it does.
And, no, flooring it won't flood it, assuming it's flooded already. You are letting more air in, which purges the fuel.
Old 02-26-2004, 11:35 PM   #12 (permalink)
Defector
the code works on all OBD1 cars, including 95
Help E39 Won't Start SKT174 5-Series (E12,E28, E34, E39, E60) 12 07-25-2009 10:03 AM
Car Won't Start - Help - Fuel Pump Relay? e36is 3-Series (E36) 24 09-08-2005 05:51 PM
'93 325i Won't Start 86VFR750R 3-Series (E36) 3 12-05-2004 08:32 AM
Why Won't She Start? nicolecass81 3-Series (E36) 4 11-09-2004 05:38 PM
325I won't start in heavy SUNLIGHT 325iconverted 3-Series (E21, E30) 3 07-09-2004 12:15 AM
