A car w/ ABS/AST-Is bleeding the brakes - BMW Forum - BimmerWerkz.com
Old 05-20-2004, 12:28 PM   #1 (permalink)
alonzomosley is an unknown quantity at this point
Is bleeding the brakes necessary after changing the front brake pads and rotors on a car that has an ABS/AST brakeing/traction system?
I have a 1994 325ic and I would like to change the front brake pads and rotors but I am not confident enough to bleed the system. I have read that cars with ABS/AST brakeing need specific bleeding procedurs that should only be performed by a dealer for safety reasons...Source(3 series service manual by Bently Publisers)
Aslo;
The manual states in the caliper removal section "to loosen the brake hose fitting"
It also goes on to state that if any bake fluid was removed or loosened that the system must be bleed.
1.) Can I remove the calipers w/o loosening the brake hose fitting -If so are there any repurcussions?
2.) Does anyone have a quality source that describs the brake bleeding procedures for a car w/ ABS/AST?
Thanks,
Alonzo Mosely
alonzomosley is offline   Reply With Quote
Old 05-20-2004, 12:35 PM   #2 (permalink)
Car: 2008 128i
Welcome to the forums.
Bleeding the system won't hurt (unless you do it wrong or break something.) and couldnt be a bad idea...
i belive its same as any other car to bleed the system.
2008 128i Jetblack
Old 05-20-2004, 12:45 PM   #3 (permalink)
Thanks...
I have bleeding procedures but it is not recommneded for cars w/ ABS/AST setup. So I don't plan on using it. Do you know of a site that might have a procedure for cars w/ ABS/AST setup?
Old 05-20-2004, 12:56 PM   #4 (permalink)
Thanks...Can you recommend another site that might have procedures posted?
Old 05-20-2004, 01:08 PM   #5 (permalink)
Car: 2008 128i
Try the FAQs.
there maybe something there.
2008 128i Jetblack
Old 05-20-2004, 01:15 PM   #6 (permalink)
heifetz17's Avatar
heifetz17 is an unknown quantity at this point
Send a message via MSN to heifetz17
I believe bleeding is necessary no matter what kind of braking system you have. Am I wrong?
heifetz17 is offline   Reply With Quote
Old 05-20-2004, 01:25 PM   #7 (permalink)
camnipotent's Avatar
camnipotent is an unknown quantity at this point
Send a message via AIM to camnipotent Send a message via MSN to camnipotent
I would think you're right. You have to top off the fluid as it is, and any air bubbles would cause serious problems. Bleed them.
<span style='font-size:8pt;line-height:100%'><span style='color:blue'>1998 BMW 323is Coupe, Black
Manual
18&quot; M3 Hyper Silver Rims
2 12&quot; Rockford Fosgate Subs; Sealed
1.0 Farad Capacitor
800 Watt 2-Way Rockford Fosgate Amplifier</span></span>
camnipotent is offline   Reply With Quote
Old 05-20-2004, 02:35 PM   #8 (permalink)
Defector
El Presidente's Avatar
It is best to bleed the brakes, top off fluid, and change the pads and rotors at the same time. Rarely do all occur at the same time. If you wanted to, you can bleed them. If they don't feel like they need it, then don't owrry about it. However, the best time to top off the fluid is when all pads and rotors are new, so that way the calipers are at their max setting. If you bleed and top off when the pads are worn down, when it comes time to change the pads, you will actually force fluid out of the system.
Old 05-23-2004, 07:16 PM   #9 (permalink)
Thank you all for your input...I appreciate it.
problems starting car when cold... VLAD_325is 3-Series (E36) 8 09-12-2005 08:08 PM
Steering Shaking With And Without Hot Brakes zanick 3-Series (E46, E90) 3 10-26-2004 11:02 AM
Bleeding Brakes 325driver 3-Series (E36) 11 05-24-2004 03:59 PM
bleeding abs brakes crjdriver 5-Series (E12,E28, E34, E39, E60) 1 09-09-2003 03:18 PM
