| ptaylor: What I believe that you are hearing is the secondary air pump turning on. The reason you are hearing a "vacuum" sound and why the check engine light is because you either a. have a near-death sec. vac. pump b. have a leaking hose/connection or c.other leaking vac. hoses. It is normal to hear the sound a little, but from what you have described it sounds as if there is most likely a leak and this also contributing to the check engine light.
There is one other possiblility but I don't feel is near as likely because of the ability to "turn itself off". And that is the crankcase vent valve. When these things go bad on the 4 cyl. they usually make a real loud vac. sound and will also cause unresponsiveness with the engine.
So, you either need to attempt to examine the car yourself or take it to a qualified reputable repair facility and have the faults read.
Good Luck!!!
Everything BMW
921 J Place, Suite 200
Plano, TX 75074
469-767-3309
OEM Repairs and Maintenance
Extended Warranty Service
Pre-Purchase Inspections
STETT Performance Official Grand Opening BMW Meet, May 6th 11A-3P -- Music, Food, Drawings and Tons of BMW's go to http://206.123.107.13/stett and register.. it's FREE |
