Car Shakes At Idle - BMW Forum - BimmerWerkz.com
Old 03-19-2005, 06:39 PM   #1 (permalink)
fushuman is an unknown quantity at this point
Arrow
I don't know why when my car is warm and idling, the car lightly shakes sideways and feel rough. Now this doesn't happend everyday and cleaned the ICV, replaced spark plugs and O2 sensor. The car has no CEL on and it still has good gas milage. Is there anything else i should check? any suggestions will help.
<img src='http://www.bmw-forums.com/forum/uploads/photo-7050.jpg' border='0' alt='user posted image' />
CONQUER THE WORLD WITH YOUR <span style='color:red'>HEART</span>!!!!!
CONQUER THE RACE WITH YOUR <span style='color:blue'>SOUL</span>!!!!
fushuman is offline   Reply With Quote
Old 03-20-2005, 05:34 AM   #2 (permalink)
swindon_matt_uk is an unknown quantity at this point
Send a message via MSN to swindon_matt_uk
I've noticed all BMWs rock a little when idle. I think its the way the engine is mounted.
<span style='font-size:14pt;line-height:100%'>-=CheeRS=-</span>
<img src='http://www.swindonmatt.plus.com/sig.JPG' border='0' alt='user posted image' />
swindon_matt_uk is offline   Reply With Quote
Old 03-20-2005, 06:29 AM   #3 (permalink)
69th Gear Member
BeachBunny's Avatar
Car: 1996 328IS
BeachBunny has a reputation beyond reputeBeachBunny has a reputation beyond reputeBeachBunny has a reputation beyond reputeBeachBunny has a reputation beyond reputeBeachBunny has a reputation beyond reputeBeachBunny has a reputation beyond reputeBeachBunny has a reputation beyond reputeBeachBunny has a reputation beyond reputeBeachBunny has a reputation beyond reputeBeachBunny has a reputation beyond reputeBeachBunny has a reputation beyond repute
I've found that mine does that too sometimes... I'd heard something about "the BMW rattle" somewhere on this forum?
BeachBunny is offline   Reply With Quote
Old 03-20-2005, 11:35 AM   #4 (permalink)
So is there a cure for the "BMW rattle"?
if i change my engine mounts, would that help or is there something else i should check?
Old 03-20-2005, 02:43 PM   #5 (permalink)
quality
Delmarco's Avatar
my car does the same thing...the RPM vibrates and the car kind of lurches forward as if its some wild dog on a leash trying to run off. I've noticed this sometimes when I'm stopped at a red lights, mostly if the car is idling at at red light on a hill going upwards.
Old 03-21-2005, 02:47 AM   #6 (permalink)
Its nothing to worry about. Changing the mounts won't help at all.
Old 03-21-2005, 03:14 AM   #7 (permalink)
illwasteyou's Avatar
illwasteyou is an unknown quantity at this point
Send a message via MSN to illwasteyou
my hypothesis is that it shakes when youre low on fuel.
ive also gathered that when low on petrol the engine sounds like a rotary.
<img src='http://img.photobucket.com/albums/v335/illwasteyou/si3.jpg' border='0' alt='user posted image' />
illwasteyou is offline   Reply With Quote
Old 03-21-2005, 08:30 PM   #8 (permalink)
Linds's Avatar
Linds has a reputation beyond reputeLinds has a reputation beyond reputeLinds has a reputation beyond reputeLinds has a reputation beyond reputeLinds has a reputation beyond reputeLinds has a reputation beyond reputeLinds has a reputation beyond reputeLinds has a reputation beyond reputeLinds has a reputation beyond reputeLinds has a reputation beyond reputeLinds has a reputation beyond repute
Send a message via AIM to Linds
Mine does the same thing. I ran the fault code reader and it turned out to be the ignition coil. Check it just in case!
Coming soon...
Linds is offline   Reply With Quote
Old 03-21-2005, 09:40 PM   #9 (permalink)
abemcclellan's Avatar
abemcclellan is an unknown quantity at this point
mine does the same damn thing. except mine missfires too randomly when it idles. i was thinking mine has like a weak coil or something. does anybody know how to check the ignition coils, besides like taking each of them out singlely and replacing it with a new one, and drive it around and see if its better? i was wondering if i could somehow check the voltage on each one if its possible and see which ones where weak.
abemcclellan is offline   Reply With Quote
Old 03-21-2005, 10:15 PM   #10 (permalink)
well if you have acess to a scan tool to read out which cyl is missing you can take that coil out and swap it with another known good coil and when it mises out check the codes and see if the miss moved along with the coil.
Old 03-22-2005, 01:33 PM   #11 (permalink)
Linds's Avatar
[snapback]316085[/snapback]
If you do find out that it's the ignition coil(s), you should get them from pelicanparts.com. You'll save around $30 off the price that the dealer wants.
Coming soon...
Old 03-22-2005, 04:59 PM   #12 (permalink)
But my CEL is not on, and i don't have any faulty codes on the computer so far.
I'll inspect the coils anyway to see if there working properly
Old 03-22-2005, 06:14 PM   #13 (permalink)
you cans till have a misfire fault and no CEL but if you said that it shakes all the time so i doubt it is a missfire i think it is jsut the nature of the beast a lot of E36 have a similar vibration.
when i turn on the ac in my car and i am at idle the engine idle fluctuates ? träumer 3-Series (E21, E30) 0 11-01-2005 02:39 AM
whats up with my e30 it shakes like a diesel at idle? träumer 3-Series (E21, E30) 8 10-14-2005 10:32 PM
Warmed up idle puzzle. nightsurfride 3-Series (E21, E30) 2 02-03-2004 08:04 PM
