Car Pulls Under Braking - BMW Forum - BimmerWerkz.com
post #1 of 8 (permalink) Old 07-16-2005, 07:06 PM Thread Starter
victorgallas is an unknown quantity at this point
on my 325i ive noticed my car pulls to the side when coming to a stop like on a traffic light. It only pulls when under light/moderate braking and only happens at low speeds , below 20.
My rotor, calipers and pads are brand new, the whole system has been bled twice recently, and i have no abs lights on. Ive alsready checked wires and plugs from sesnors all seems good.
When i tested the abs, by stonping the brakes until the car stops, the abs work fine, does not pull or anything.
I am wondering is someone outthere can give me some ideas on waht to do:/
Does someone knows how i can activate the abs pump to open the valves so when i bleed the brakes i will be sure all fluid is being pumped out of the abs pump;;;;
plase this is bothering me and driving me nuts and the the car sideways;;
let me know please......!!!
You are a BMW driver when you become part of the "Ultimate Driving Machine"
Fraude an Fahren
BMW > Bayerische Motorenwerke
Auf Viedersehen der herr
victorgallas is offline
post #2 of 8 (permalink) Old 07-16-2005, 07:11 PM
The last time this happed to me, I pulled the guide bolts (sliders) cleaned them up and then lubed them with Moly Lube and that did the trick.
Bear is offline
post #3 of 8 (permalink) Old 07-17-2005, 05:50 AM
///M Power's Avatar
Quoted: 2 Post(s)
///M Power has a reputation beyond repute ///M Power has a reputation beyond repute ///M Power has a reputation beyond repute ///M Power has a reputation beyond repute ///M Power has a reputation beyond repute ///M Power has a reputation beyond repute ///M Power has a reputation beyond repute ///M Power has a reputation beyond repute ///M Power has a reputation beyond repute ///M Power has a reputation beyond repute ///M Power has a reputation beyond repute
When was the last time you aligned you suspension all together? Have you recently done suspension work?
///M Power is offline
post #4 of 8 (permalink) Old 07-17-2005, 09:49 AM Thread Starter
[snapback]362963[/snapback]
Car has been fully aligment not more than a monh ago, but this problem has been going on for a while, so i dont think is aligment.
Car drives fine, does not pull or anything, and balanement is also ok...
ill check the guide bolts, but i doub this is the problem since i am usng Bavauto metal caliper bushings, thnaks for the help and let me know if anyone has some other inputs..
Fraude an Fahren
post #5 of 8 (permalink) Old 07-17-2005, 09:52 AM
quality
Delmarco's Avatar
Delmarco has a reputation beyond repute Delmarco has a reputation beyond repute Delmarco has a reputation beyond repute Delmarco has a reputation beyond repute Delmarco has a reputation beyond repute Delmarco has a reputation beyond repute Delmarco has a reputation beyond repute Delmarco has a reputation beyond repute Delmarco has a reputation beyond repute Delmarco has a reputation beyond repute Delmarco has a reputation beyond repute
This sounds like "TIRES".
Check and Adjust tire pressure on ALL 4 TIRES.
Also check for tread wear and replace worn TIRES if needed.
Delmarco is offline
post #6 of 8 (permalink) Old 07-17-2005, 02:14 PM
Avlany's Avatar
Avlany is an unknown quantity at this point
Yeah, what Delmarco said, as well as check your rims for deformations (it might be slightly bended and it couse the problem you have).
Dont piss me off. I am running out of places to hide the bodies
<img src='http://members.dslextreme.com/users/avlany/images/BMW%20banner.gif' border='0' alt='user posted image' />
Avlany is offline
post #7 of 8 (permalink) Old 07-17-2005, 06:35 PM Thread Starter
[snapback]363026[/snapback]
All four tires are brand new, less than 15k on them, and tire pressure is also chekked every week on all four corners. so i knows this is right.
my rims are sligtly out of round, very little though, i did not think this little would be enought to cause this problem,,
any other ideas let me know please.
thank you all.
You are a BMW driver when you become part of the &quot;Ultimate Driving Machine&quot;
Fraude an Fahren
BMW &gt; Bayerische Motorenwerke
post #8 of 8 (permalink) Old 07-17-2005, 06:52 PM
Avlany's Avatar
Originally posted by victorgallas+Jul 17 2005, 03:35 PM--><div class='quotetop'>QUOTE(victorgallas @ Jul 17 2005, 03:35 PM)</div><div class='quotemain'><!--QuoteBegin-Avlany@Jul 17 2005, 01:14 PM
thank you all.
[snapback]363081[/snapback]
[/b][/quote]
I had my rims a little bended as well (2 of them), and my problem was gone after i replaced all of them (i could've just repair it in shop but decided to move on with new style)
Avlany is offline
Chip Made My Car Slower gonzonick 3-Series (E36) 12 10-25-2005 03:46 PM
problems starting car when cold... VLAD_325is 3-Series (E36) 8 09-12-2005 09:08 PM
