Car Overheated Last Night. Help! - BMW Forum - BimmerWerkz.com
Old 11-14-2004, 01:42 PM   #1 (permalink)
jroberts312 is an unknown quantity at this point
wife was driving car last night. Car started to smoke. She was not too far and was able to drive home. Car was at red indicator. Opened hood and antifreeze was everywhere and mainly toward back of engine. Looked this morning. Hoses look fine. Added water and it started to leak from rear of engine. Anyone know what this might be?
jroberts312 is offline   Reply With Quote
Old 11-14-2004, 01:50 PM   #2 (permalink)
What? No Autobahn?
jrhaile's Avatar
Car: 2001 M5
jrhaile jrhaile jrhaile jrhaile jrhaile jrhaile jrhaile jrhaile jrhaile jrhaile jrhaile
Send a message via ICQ to jrhaile Send a message via AIM to jrhaile Send a message via MSN to jrhaile
you probably can't see it, but there is another hose lower on the rear of the engine that goes into the engine. it probably broke. I can't believe she drove it while on red. take off the intake manifold and you'll see the hose. You'll be lucky if the engine didn't burn any components.
jrhaile is offline   Reply With Quote
Old 11-14-2004, 03:30 PM   #3 (permalink)
billB's Avatar
Sounds like heater hoses; just hoping she didn't burn the head gasket. rather expensive job.
good luck
billb
Old 11-14-2004, 06:28 PM   #4 (permalink)
Yeah you guys were right. It is the bypass or heater hose. It had come off. I tried to reconnect it and tighten clamp. I drove the car around and it seemed to be okay. I drove it up driveway and opened hood to see if there were anymore leaks. I was about to claim it fixed and bam, it came off again. Antifreeze shot all over the engine again. The hose is weird. It is 1" on one end and 3/4" on the other. The 1" end is the end that comes off. Could there be another reason why the hose comes off other than it is just bad. The end does not allow you to mount it well. Any thoughts?
Old 11-14-2004, 06:58 PM   #5 (permalink)
billB's Avatar
Jroberts
I would get a new hose not much $$ if too tight to mount a drop of oil will do the trick, just make sure to get a good quality hose/clamps. Try not to use the old hose simply it is dry from the heat and it may crack again at the wrong time in the place.
good luck
billb
Old 11-14-2004, 07:27 PM   #6 (permalink)
kearnyme's Avatar
kearnyme is an unknown quantity at this point
Since the block is aluminum its NEVER a good idea to drive it when its on red, if it gets hot just stop and call for a tow truck, don't try and make it.. you'll be sorry.
I have a friend thats a mechanic and he told me about a lady who drove an older 750il while it was overheating, yeah she made it ito the gas station, but the engine was TOAST..
I'm glad to hear thats not what happend with your car!!!
____\_________/____
<u>/|OO| [llllll][llllll] |OO|\</u>
<u>| o |llllllllllllllllllllllllll| o |</u>
My sh*t is not disco. Thank You.
<img src='http://home.insightbb.com/~shahabm3/wsb/media/1063900/site1013.jpg' border='0' alt='user posted image' />
kearnyme is offline   Reply With Quote
Old 11-15-2004, 06:54 AM   #7 (permalink)
DarrellS is an unknown quantity at this point
[snapback]230929[/snapback]
Man,
If I were you I'd go and get a pressure test done straight away. Those hoses under normal pressure should stay on but if you have a build up of pressure forcing it off it's very possible you have a cracked/warped head or knackered head gasket. I might be being a bit of a drama queen here but please save doing anymore damage by driving it and go get it tested, they can test the block at the same time.
Good luck my friend.
DarrellS is offline   Reply With Quote
Old 11-15-2004, 09:51 AM   #8 (permalink)
Found what the problem was. The hose connects to a plastic piece that broke off inside the hose. What is this part called? It connects to the block.
Old 11-15-2004, 11:37 AM   #9 (permalink)
[snapback]231216[/snapback]
Old 11-15-2004, 11:40 AM   #10 (permalink)
Originally posted by Bear+Nov 15 2004, 11:37 AM--><div class='quotetop'>QUOTE(Bear @ Nov 15 2004, 11:37 AM)</div><div class='quotemain'><!--QuoteBegin-jroberts312@Nov 15 2004, 09:51 AM
Found what the problem was.* The hose connects to a plastic piece that broke off inside the hose.* What is this part called?* It connects to the block.
[snapback]231281[/snapback]
[/b][/quote]
I am a E32 guy, but is the plastic piece the nozzle off of the expansion tank, I had this happen on my 750 and the metal bushing inside the plastic piece had slid forward into the hose and you could not a grip on the hose to tighten (plastic kept collapsing) I tapped the bushing back in place and all has been well for several months.
Me on my car, on the Freeway! 325eXTATIC Picture Showroom 20 01-19-2006 10:49 AM
Chip Made My Car Slower gonzonick 3-Series (E36) 12 10-25-2005 02:46 PM
problems starting car when cold... VLAD_325is 3-Series (E36) 8 09-12-2005 08:08 PM
