Car Heating Up - Please Help - BMW Forum - BimmerWerkz.com
Old 10-05-2004, 06:29 PM   #1 (permalink)
alext is an unknown quantity at this point
Gentleman, I have a 1997 318I, last month car overheated on the freeway, the reason was the plug in the engine block, it was replaced. Later in 2 weeks, temperature gauge started moving to the right so I had to let the car cooled down in order to drive it to the shop. They replaced the thermostat 'cause it wasn't letting enough water pass to cool the car down. It was fine for a couple of weeks, and I was driving in the freeway until the temperature gauge started to move to the right again, I had to stop a gas station and let the car cooled down, I checked the radiator and the oil and they were fine. I drove it to the autoshop (about 5 miles) and the gauge moved to the right again so once again I had to stop to let it cooled. I waited for a couple of hours and I drove it to the shop finally and this time the car didn't heat up. The mechanic is checking it right now but IS THE WATER PUMP DONE? OR WHAT ELSE COULD IT BE? PLEASE HELP,
THANKS A MILLION AHEAD OF TIME.
alext is offline   Reply With Quote
Old 10-05-2004, 07:05 PM   #2 (permalink)
RIBEMR26's Avatar
What was wrong with the block plug that caused it to overheat the first time?
Clear Corners and Sidemarkers
Old 10-06-2004, 10:27 AM   #3 (permalink)
[snapback]205549[/snapback]
Nothing was wrong with the car before the plug was damaged. Dealer stated that was very uncommon to have a problem with the block plug but that everything besides that was OK. The only problem that I had before was that the A/C would turned on and off by itself but that was fixed by the dealer (it costed me some nice cash too). Is the water pump the problem right now? or is there something else I'm missing. Ratiator and Oil levels are ok.....please any help would be appreciated. Thanks in advance.
Old 10-06-2004, 10:45 AM   #4 (permalink)
Dinan 95 is an unknown quantity at this point
It has to be your water pump.
When was the last time you had the radiator flushed?
Stupid question but if you haven't done it in forever that could be a major part of the problem.
Also radiators do have a shelf life, your level may be ok ,but if the core is toast it won't cool worth a darn.
318I convertible, Dinan Exhaust and performance chip
Roh BMW racing 17's, Dinan Stage 2 suspension system. Pinoeer CD player, pioneer speakers front and rear. Pioneer 400 watt 6 channel amp. and MTX 8&quot; subwoofer.
35,000 miles
Dinan 95 is offline   Reply With Quote
Old 10-06-2004, 01:02 PM   #5 (permalink)
bonsai is an unknown quantity at this point
Another thing you can check is the fan clutch. Fan clutch takes a very important task to cool down the radiator. It is very easy to check the fan clutch to see if it is bad. Step on gas as engine run faster (RPM) so as fan clutch. if the fan clutch turn slow its time to replace it.
bonsai is offline   Reply With Quote
Me on my car, on the Freeway! 325eXTATIC Picture Showroom 20 01-19-2006 10:49 AM
94 m-technic in AZ adamsbomb Cars For Sale 8 12-14-2005 11:43 PM
Chip Made My Car Slower gonzonick 3-Series (E36) 12 10-25-2005 02:46 PM
problems starting car when cold... VLAD_325is 3-Series (E36) 8 09-12-2005 08:08 PM
